Varnish brushes - SailNet Community
 7Likes
post #1 of 42 Old 02-27-2013 Thread Starter
Varnish brushes
I'm pretty good at cleaning brushes, but wondered if there were any tricks for holding a brush over to be re-used the next day. Using a badger brush. I have 10 coats of varnish I'm planning to apply and dread the thought of all those intermediate cleanings.
Would a light cleaning and then just hang in mineral spirits until the next day work?
Jeanneau 54DS
Minnewaska is offline
post #2 of 42 Old 02-27-2013
Re: Varnish brushes
I usually give the brush a quick cleaning and then seal it in plastic wrap and its good to the next day or two. I've found disposable sponge to work just as well as a bager brush and less work.
captain conrad is offline
post #3 of 42 Old 02-27-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: Varnish brushes
I assume you're talking about a single-pack varnish like Epifanes??
If so, yes, hanging it (not just chucking it in a tin) in mineral spirits overnight is fine. If you just want a break for lunch, wrapping the brush as-is in plastic wrap and keeping it out of direct sunlight (or, even better, in the yard fridge!) will keep it for an hour or four..
Classic30 is offline
post #4 of 42 Old 02-27-2013
Sabreman's Avatar
Re: Varnish brushes
Simple an easy. It's an old trick that I learned working in a marina. I've been using this technique for years without trouble.
1. Put about 1/4" of mineral spirits in a cup and work the brush back and forth until the liquid is amber/cloudy. Empty. Refill. Repeat.
2. Stand the brush in the spirits as vertical as possible OR hang using a heavy wire inserted through the handle and across the lip of the cup.
3. Ensure that the bristles are in the spirits and just touching the cup's bottom.
No need for more than 1/4" - 1/2" of spirits.
Don't store this way for more than a day or the bristles will permanently bend and what's left (if any) of the solids will settle.
4. The next day, remove the brush and dry using a vigorous "throwing" motion, 5-10 "throws".
5. Keep the spirits in the cup for your first cleaning.
6. Sand your work, while letting the brush dry a bit. if it's too wet, you'll thin your first coats of finish
Sabre 38 "Victoria"
Sabreman is offline
post #5 of 42 Old 02-27-2013
Tartan 37C
T37SOLARE's Avatar
Re: Varnish brushes
This is what I use for my varnish brushes:
Paint Brush Keeper
SOLARE
T-37 #442
T37SOLARE is offline
post #6 of 42 Old 02-27-2013
Re: Varnish brushes
Another vote for the foam brush.
Seaduction is offline
post #7 of 42 Old 02-27-2013
Re: Varnish brushes
For those into 'serious varnishing' I recommend a look at Epifanes website. Although I used epifanes on my cabin sole, their recommendations for surface prep, brushes, thinning, recoating, etc. work with lots of wood finish products.
Here's a link: Epifanes Questions and Answers
post #8 of 42 Old 02-27-2013
Re: Varnish brushes
Agree, I have used both and can't beat the foam, and they are cheap, no need to clean, just use a new one for the next coat.
Paul T
dabnis is offline
post #9 of 42 Old 02-27-2013
Re: Varnish brushes
One trick for the hardware store foam brushes, they are coated to prevent absorbing stuff pre-sale so you have to "knead" them a little before use. I couldn't get good results until an old pro told me I wasn't using a piece of foam on a stick right.
capttb is offline
post #10 of 42 Old 02-27-2013
Re: Varnish brushes
Ha-haaaargh, tis the time of year when a pirate's thoughts turn to varnishin...
MarkSF is offline
After brushes with death, sailboat owner takes West Linn grounding in stride - Oregon NewsReader News Feeds 0 08-18-2011 06:10 AM
Varnish grinfax Gear & Maintenance 7 07-30-2008 04:20 PM
Cleaning badger hair brushes JimOppy Gear & Maintenance 9 02-25-2006 08:24 PM
varnish mikehoyt Gear & Maintenance 0 06-03-2004 06:29 AM
Chip Brushes pirateofcapeann Gear & Maintenance 1 08-26-2003 06:04 PM
