Propane tank adapter - SailNet Community
 2Likes
post #1 of 13 Old 02-28-2013 Thread Starter
THEFRENCHA's Avatar
Hello all
I havé ŕ propane stove / oven connected to a large propane tank
The Home Depot type not the aluminium marine tank
I would like to use a small 1lbs canister instead but do not want to change all the lines nd hoses There must be some sort of adapter that I could use but I just cannot find any at WM or Defender
Maybe on the Internet ?
If you could help that would be great
Thanks
THEFRENCHA is offline
post #2 of 13 Old 02-28-2013
Skipper Jer's Avatar
Re: Propane tank adapter
You want to connect the small canister to the stove or where the large tank connected at? I'd check ebay, or here:
Propane Burner Parts, Miscellaneous Propane Burner Parts
I have no connection (pun not intended) to either places.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #3 of 13 Old 02-28-2013
pete
Check cabbalas
beachmont is offline
post #4 of 13 Old 02-28-2013
Dirt Free
boatpoker's Avatar
Sounds like another dubious propane installation.
mitiempo and rugosa like this.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #5 of 13 Old 02-28-2013
chef2sail's Avatar
Coleman 1-Pound Propane Tank Adapter: Camping : Walmart.com
Please do not do a direct connect of 1lb propane tank for this usage in the vessel. Propane is heavier than air and will sink to the lowest point of the boat and wait to explode. I am sure the hosing to the ouside tank probably has a solenoid shut off for a reason,,,,protection. These 1 lb tanks teak after they have been removed sometimes and the valve sticks open
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #6 of 13 Old 02-28-2013 Thread Starter
THEFRENCHA's Avatar
Hold on !
I just want to find an adapter that would fit in the knob, where it is attached to the tank
So even if using a canister, this partwill be in the locker , next to the now disconnected propane tank
I do not intend to connect directly to stove !!!!!
Thanks
post #7 of 13 Old 02-28-2013
OPossumTX's Avatar
OHHH YESSS! I have had to discard a few because they leaked. Sometimes the little valve just doesn't cut off when the tank is removed from the fitting.
You won't hear it, you won't see it but if your nose is working, you can usually smell it.
OPossumTX is offline
post #8 of 13 Old 02-28-2013
Jiminri's Avatar
Originally Posted by THEFRENCHA View Post
Hold on !
Thanks
If I understand what you're looking for, Defender.com sells these and offers a couple of different brands. See, for example:
Trident Marine LPG Propane Gas Reserve Bottle Adapter
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #9 of 13 Old 02-28-2013 Thread Starter
THEFRENCHA's Avatar
Thanks to Beachmont and Jimrini
Found it on Cabelas.com and Defender
Better price on Defender!
In my case, A big tank last for years as I mostly use the microwave for coffee
I would like to see if a canister will do the season
I am on a mooring so carrying this big heavy tank for a refill is just something I could do without
Thanks
post #10 of 13 Old 03-01-2013
Very common adapter, as linked by others. Most often used to have a 1lb tank on hand as a backup if you empty your large tank.
If you are trying to store the 1lb tank with your large tank, the longer thinner torch tanks sometimes fit better.
Jeanneau 54DS
Minnewaska is offline
propane tank gregreinhard Gear & Maintenance 5 03-04-2013 01:09 PM
S/S Propane Tank? jppp Gear & Maintenance 11 11-27-2011 05:48 PM
Propane Tank Funsail C30 1 03-12-2011 10:33 AM
Propane tank location brak Gear & Maintenance 15 06-15-2007 01:37 PM
Propane tank Irwin32 Gear & Maintenance 10 01-21-2006 06:58 AM
