Flange failure - SailNet Community
post #1 of 1 Old 05-11-2004 Thread Starter
foxglove's Avatar
Flange failure
This last weekend, the flange connecting the shaft to the v-drive on my Pearson 323 failed. Closer inspection showed that the shaft had parted at the flange having sheared all three flange bolts.
Just prior to the failure, I smelled something hot in the cabin. It might have been the fluid in the v-drive. This was the first outing of the season and I don''t think I wrapped anything on the prop but I suspect drag on the shaft as a possible cause. I might note that the shaft was free-wheeling during the tow back to the marina although it was making a ''clunking'' sound as it turned.
The shaft and cutlass bearings were replaced only two years ago. I assume that the flange and bolts would have been replaced as well. I hope they are not the problem.
I am awaiting an opinion from a nearby yard about whether the boat should be hauled for inspection before re-connecting the shaft.
Does anyone have experience or thoughts about this problem? Should I ask for a haul out even if the yard doesn''t think it''s necessary? Can anyone think of a reason for the failure other than the 20 years of age on the v-drive? Is this a big repair?
Thanks for any responses.
foxglove is offline
Holding Tank Failure BillG501 Gear & Maintenance 3 09-23-2006 05:34 AM
Seatalk failure Mkfcdl Gear & Maintenance 2 09-20-2005 06:05 AM
Inverter failure???? bderosa Gear & Maintenance 2 03-26-2004 06:15 PM
Salt Water Cooling System failure. rclampitt Gear & Maintenance 4 07-28-2002 09:26 PM
Hunter vs. Beneteau PASailor Boat Review and Purchase Forum 10 11-12-2000 07:04 PM
