03-01-2013
Re: Radar mast mount from fiberglass?
Originally Posted by szigi
Balsa core. That is a good idea! Or it could even be cut from urethane foam panels.
Sure all holes for fasteners would be oversize, and filled with thickened epoxy, as it should be with other cored stuff. I'll make some calculations on the weight and strength, and see what comes out I've been thinking about the stress caused by movement, and the flexibility of fiberglass may even be an advantage. provided the mounting points are strong enough to not crack.
No sharp edges or burrs or you be sewing your mainsail. Most of these are around $250 new, and Ill bet if you call a place like Bacins in Annapolis, MD they have used ones cheaper.
As Faster mentioned, even the new ones are somewhat heavy and I dont think placing it out on a spreader is neccessarily a good idea for balance or weight. Usually they are on the mast or like ours on a radar pole on the stern of the boat. Or radar pole has a closed hoop over the radar dome that serves as the anttannae mount for the GPS, stern light,TV anatannae and also the attachement for our dinghy engine hoist.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
