Self steering on wheel steered boats - SailNet Community
 5Likes
post #1 of 20 Old 03-01-2013 Thread Starter
krisscross's Avatar
I am in the process of selecting a boat for limited offshore sailing (NC to Bahamas) - already started a thread on that in general discussion forum. As I am planning to sail solo, I need a self steering capability (like a wind vane systems). I know how these system work on tiller steered boats, but some of the boats I am considering have wheel steering. Is that going to be a problem? What are your experiences with self steering mechanism on wheel steered boats?
krisscross is offline
post #2 of 20 Old 03-01-2013
1982 Skye 51
obelisk's Avatar
Re: Self steering on wheel steered boats
The wheel adapter on my Aries wind vane is burly, offers a fine-tuning adjustment, easy to use and has never given me any problem. Bonus is that you can run the control lines down the same side of the cockpit to free up some room.
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
post #3 of 20 Old 03-01-2013
we use a Monitor to the wheel on our Pacific Seacraft 34
Works great, but it will make you properly trim the sails
We also tow a warp down wind with big seas to make it work better.
jrd22 likes this.
hughdon is offline
post #4 of 20 Old 03-01-2013
I'm very satisfied with my Cape Horn wind vane. All of the connections are below decks, no lines in the cockpit or attached to the wheel. It also has the ability to connect a small tiller autopilot to it, haven't taken that step yet. Does a good job going downwind too!
Tyler
S/V Ro'annon
HC 33
sevennations is offline
post #5 of 20 Old 03-01-2013 Thread Starter
krisscross's Avatar
Thanks, guys
Does it make a difference what wheel steering system is used (worm gear vs pedestal)?
post #6 of 20 Old 03-02-2013
Bristol 45.5 - AiniA
Consider whether you need a vane for the type of cruising you plan long-term. An electric autopilot offers greater flexibility eg use with engine, turn on/off more easily. A vane really comes into its own for extended passage-making.
jrd22 and Minnewaska like this.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #7 of 20 Old 03-02-2013 Thread Starter
krisscross's Avatar
Good point and I'm planning to have an autopilot as well. I was thinking of having self steering as a reliable backup system to it.
post #8 of 20 Old 03-02-2013
I've known people to have wind-vanes and I've always assumed I would do the same, if we ever take off on one of our bucket list adventures.
However, as time passes, I've been considering where I would be better off to have redundant autopilot components instead. Stocking all the parts to address points of failure is probably not that different from what it would cost us to fit a Monitor. The ideal would be to have a redundantly installed autopilot system. I've ever heard of that being done.
Big advantage of some windvane systems is the ability to have an emergency rudder.
Jeanneau 54DS
Minnewaska is offline
post #9 of 20 Old 03-02-2013
Fitting a small electric tiller-arm autopilot to a Monitor is easy to do.
Then it works with no wind (calm conditions).
You 'trick' what the Monitor responds to by substituting the autopilot push-pull for the windvane and the hydrovane still does all the work.
We also have an old backup reliable electric CPT wheel pilot that works well. I believe these simple strong units are now built in California (originally Fla).
hughdon is offline
post #10 of 20 Old 03-02-2013
Friends who've done similar cruising (BC to Mexico, then 3 seasons up and down Mexico's coast) put a Hydrovane on their Passport 40, as well as a below decks autopilot (RM). The Hydrovane worked well (a wonderful piece of engineering, and it also provides the 'spare rudder' mentioned above) but they ended up using the autopilot much more often.
Faster is offline
Steering wheel size ichorniy General Discussion (sailing related) 26 07-18-2010 08:19 PM
D/A steering wheel wchevron Gear & Maintenance 0 03-25-2008 01:37 PM
wheel steering spectre2 General Discussion (sailing related) 8 09-14-2004 01:47 AM
Steering Wheel Hub BertV Gear & Maintenance 4 08-28-2003 07:31 PM
Wheel Steering cmlambpsi Racing 2 09-06-2001 05:58 PM
