Rope Halyards - What brand / type do you recommend? - SailNet Community
 1Likes
post #1 of 20 Old 03-01-2013 Thread Starter
Maine Member
BELLATRIX1965's Avatar
Greetings all:
Going to all-rope halyards (Main and 2 Genoa halyards - all internal). The old wire halyards must go!
I am limited to 3/8" (10mm) size, due to size constraints at the masthead sheave box (and rope clutches, and winch self-tailer size - you know the drill). I plan on installing new 3" Harken ball bearing sheaves at the masthead (yeah - Ouch, but they fit perfectly!) to replace the existing wire-halyard sheaves.
The question is this: What do you recommend for a low-stretch (better than StaSet X) line in 3/8" diameter? I am a cruiser, so ultra high-tech line and fancy splices are out (too expensive). The boat is a 40 foot full keel sloop, so the load will be a factor. I'm considering Samson "Warpspeed" and NE Ropes T-900 - any suggestions for rope and where to buy it????
Thanks in advance!
BELLATRIX1965 is offline
post #2 of 20 Old 03-01-2013
jsaronson's Avatar
Re: Rope Halyards - What brand / type do you recommend?
If the sheaves arein good shape save your money. Try Defender.com. Pyacht is having a Harken sale.
jsaronson is offline
post #3 of 20 Old 03-01-2013
Try the rigging shop at Annapolis Performance Sailing - APS - they are very good at communicating with you and making sure you get what you really need. Splicing charges are quite reasonable too. I asked this same question a few months back and thats how I found out about APS myself.
Hope this helps ... Bruce
Bruce_L is offline
post #4 of 20 Old 03-01-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by BELLATRIX1965 View Post
Greetings all:
Thanks in advance!
We have had excellent service from West Marine's T-900 for all of our Halyards. Wouldn't use anything else and it really isn't all that expensive, all things considered.
FWIW...
svHyLyte is offline
post #5 of 20 Old 03-02-2013
arisatx's Avatar
Bellatrix:
Within the New England Ropes offerings, VPC would be your next step up from Sta Set X.
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #6 of 20 Old 03-02-2013
JimsCAL's Avatar
I've had good luck with Defender. Good prices, fast shipping, and good rigging/splicing service. They carry Samson Warpspeed. At a lower cost (but with a bit higher stretch) they carry Samson XLS Extra and MLX which both have a polyester braid cover with a Dyneema blend core.
JimsCAL is online now
post #7 of 20 Old 03-02-2013
Not Finished Yet
RainDog's Avatar
FWIW - the VPC was the Practical Sailor favorite of the "mid-range" candidates a few years back:
http://nasailor.com/2010/11/05/practical-sailor-tests-26-samples-of-rigging
RainDog is offline
post #8 of 20 Old 03-02-2013
Greetings all:
Thanks in advance!
First I don't know what you mean by "fancy splices"
Both the ropes you mention is of a core dependant construction so they need a core-to-core splice the warpspeed (at least) can be used with a uncovered splice which is (relatively) easy to do.
Knots in these ropes is not a good idea - read "How to terminate the working end of the halyards – splices vs knots" by Brion Toss Here: Brion Toss Yacht Riggers, Sailboat Rigging
Can't help you with regard to where to buy/prices.. I'm too far away
But just for fun I compared the two types you mentioned plus one more.
Warpspeed is the best rope
Assumining halyard lenght with sail hoisted, halyard load 1500 lb.
The calculations (haven figured out how to make nice tables here
Rope BL (lb) % BL EE Stretch (in)
Warpspeed 3/8 9800 15 % 0,55 % 3,3
T-900 5/16 6800 22 % 1,20 % 7,2
T-900 7/6 14300 10 % 0,75 % 4,5
VPC 6500 23 % 1,80 % 10,8
7x19 1/4 SS wire 6400 3.7
Rope Stretch (in)
Warpspeed 3/8 3,3
T-900 5/16 7,2
T-900 7/6 4,5
VPC 10,8
The raw data here.
Sampsone rope, warpspeed
Link Product
Double braid with Dyneema core
Splice Core-to-Core
3/8 BL lb 9800
ELASTIC ELONGATION at % of BL
10% 20% 30%
0.44% 0.62% 0.79%
New England Ropes, T-900
Link http://www.neropes.com/Datasheets/MAR_T900.pdf
Double braid with dyneema/Technora blend core
Splice Core-to-Core
Not available in 3/8?
5/16 BL 6800 lb
7/6 BL 14300 lb
10% 20% 30%
0.75% 1.2% 1,4%
New England Ropes, VPC
Link http://www.neropes.com/Datasheets/MAR_VPC.pdf
Double braid with Vectrann core
Splice Core-to-Core
3/8 BL 6500lb
10% 20% 30%
1.2% 1.8% 2,2%
RainDog likes this.
knuterikt is online now
post #9 of 20 Old 03-02-2013
I was faced w/ the same issue and went w/ VPC. Did my own core/core splices and will hang the halyards this spring. I was able to drop a size (3/8" v 7/16") and have very little stretch. Price is fairly reasonable too. I doubt you need the hightech stuff.
CS 36M DIANTHUS
sailordave is offline
post #10 of 20 Old 03-02-2013
Not Finished Yet
RainDog's Avatar
Link Product
Splice Core-to-Core
3/8 BL lb 9800
10% 20% 30%
0.44% 0.62% 0.79%
Splice Core-to-Core
5/16 BL 6800 lb
7/6 BL 14300 lb
10% 20% 30%
0.75% 1.2% 1,4%
Splice Core-to-Core
3/8 BL 6500lb
10% 20% 30%
1.2% 1.8% 2,2%
Here are the defender prices for 3/8:
Warpspeed: $2.87
T-900: $2.50 (defender does not sell, this is the Vela price)
VPC: $1.34
RainDog is offline
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 02:16 PM
Columbia 24'...Rope Halyards plederman Gear & Maintenance 1 07-27-2012 09:49 AM
Wire to Rope Halyards casey1999 Gear & Maintenance 16 05-23-2012 02:52 AM
halyards rope vs wire CowbaySailor Gear & Maintenance 13 07-07-2011 09:22 AM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 08:00 PM
