Transmission oil change solution? - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 03-03-2013
Closet Powerboater
MedSailor's Avatar
Re: Transmission oil change solution?
Originally Posted by bwindrope View Post
So MedSailor, do you have a link for a verified M10 hose barb with a 1.0 pitch? I've looked, at McMaster and the usual spots, and found nothing.
Nope, and when you say you looked for one and couldn't find one, I believed you. I get the impression you researched this. Also when ShockT said:
"If it were me I would have either tracked down a brass elbow with the correct thread, or failing that, had an oversized fitting machined down and re-threaded to fit."
I thought, "nope, paying a machine shop to custom make a fitting doesn't fit with either my DIY frame of mind or my "cheapskate" ideals.
All I was saying with my post was that I liked ShockT's recommendation of using a 90deg fitting for boats with tighter access and I recommended using a fitting EXACTLY like the one you used but with the 90deg elbow in it (with the JB weld) for those who have a tight spot. Basically I liked SchockT's variation on your idea, but the picture of the fitting he posted looked like it would be harder to glue one. That's all.
Nice job, and definitely a candidate for the "low buck project" thread.
MedSailor
MedSailor is offline
post #12 of 13 Old 03-04-2013 Thread Starter
Break, curse, fix, repeat
bwindrope's Avatar
No worry Med, that does seem like the best path forward. IF I lack space for the current build, then I would look for a 90 degree barb instead. As for cheap projects, the bolt was $.40 and the hose barb $2.49. I've got the hose already.
I'll resurrect this post, because it will probably now die a natural death, after I do the install and can report on whether I had any troubles. Thanks for the ideas and conversations fellow sailors!
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #13 of 13 Old 03-08-2013 Thread Starter
bwindrope's Avatar
An update and conclusion:
Turns out after making my own device as some of you had seen on my blog, that I was able to find an actual brass hose barb with the proper threads. Walbro fuel pumps use an M10 hose barb with a 1.0 pitch, and I found it at a performance auto parts store. The part number is Walbro# 128-3014. If you google this part number, you will pull up places to get it.
I've updated my blog with pictures of it installed, and you can see this at the same place as the previous link: Stories of Aeolus- Our Gulf 32 Pilothouse: Transmission oil change solution found-Updated
It was fun to make my own device, but this is a much shorter and more elegant solution. Anyone with a Twin Disc MG 360 can now install this barb to enable vacuuming the oil from their tranny bottom. Problem solved.
Aeolus
Gulf 32
Jib halyard up in the air - a solution. nightsky Gear & Maintenance 3 09-10-2010 11:24 PM
best GPS solution? jjrunning Gear & Maintenance 26 02-20-2010 06:19 AM
Traveler Set-Up -Better Solution? DrB Gear & Maintenance 7 09-27-2008 10:43 PM
A Shining Solution PracticalSailor Gear and Maintenance Articles 0 02-22-2007 10:49 AM
The Trinidad Solution John Kretschmer Cruising Articles 0 06-26-2002 08:00 PM
