High Thrust Prop for Tohatsu 9.9 on Nonsuch 22 - Page 2 - SailNet Community
post #11 of 15 Old 03-04-2013
Re: High Thrust Prop for Tohatsu 9.9 on Nonsuch 22
Going to the 10x7, is close to changing 4 quarters for a dollar. It's best to try it, before you buy it.
sony2000 is offline
post #12 of 15 Old 03-04-2013
Hinterhoeller HR28
pvanv1's Avatar
Incorrect. Look at one of the HT props. HUGE blades, negative rake... Moves a LOT of water at slow speeds. Dee http://www.rubexprops.com/prop-info/...ust-propeller/
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #13 of 15 Old 03-04-2013
tommays's Avatar
I have the smaller one for the 4/6 HP and it is a wonderfully propeller with performance that is pretty close to that of using a jet-drive lower unit
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 15 Old 03-04-2013
Hinterhoeller HR28
pvanv1's Avatar
Indeed. The 3-blade unit for the 4/5/6 is very good. Just not as sophisticated as the 4-blade units for the 8/9,8 and 9.9/15/18
Paul Van Voorhees
Buffalo, NY USA
pvanv1 is offline
post #15 of 15 Old 03-05-2013
Originally Posted by ns22simple View Post
I have a Nonsuch 22 sailboat (+/- 4,900lb) with a 1994 Tohatsu 9.9 EPL (Longshaft/2 Stroke) with a factory #8 3 blade prop (9.2" D X 7.8"P)
I desire to upgrade to a 4 blade high thrust prop. I feel there is too much slip with the stock 3 blade prop.
My first choice is the Tohatsu 4 blade 10"DX7"P high thrust (Part#3ZOB645143)
I am also aware that Solas offers two 4 blade high thrust props for this motor:
- 10"DX7"P (Part#5113-100-07)
- 10"DX5"P (Part#5113-100-05)
My first choice would be the Tohatsu.
Any advice would be appreciated.
NS22 "Simple"
I have a 20 hp Tohatsu and changed it to your first choice the 4 blade 10"DX7"P I guess you could say i was over impressed as it gave me way to much bow lift. I switch back to the 3 blade that it came with and use the 4 blade as a spare now. For me on a 23 ft Irwin was more than i needed that being said I'm a bit over powered anyway.
imprettysimple is offline
2005 Yamaha 9.9 high thrust: looking for suggestions on PM Pneumatos Gear & Maintenance 0 09-30-2012 07:44 PM
High Thrust prop ? 75R20 Gear & Maintenance 14 04-20-2010 03:57 PM
Nissan/Tohatsu 9.8 high to low altitude waltsn Gear & Maintenance 17 12-13-2009 09:51 AM
Yamaha 9.9 High thrust vs Honda Power thrust docrn General Discussion (sailing related) 1 07-27-2009 01:57 PM
high thrust propeller worth it for a 3000lb sailboat lans0012 Gear & Maintenance 2 06-24-2009 03:47 PM
