Repairing soft spot/indentation in Fiberglass sailboat hull - - SailNet Community
post #1 of 5 Old 03-02-2013 Thread Starter
1982 Edel 22' sailboat with an indentation/soft area in the hull where one of the pads for the supporting cradle is located. The indentation is about 3/4" below the hull surface. The indentation pops out when the boat is lifted out of the cradle and there are no leaks or cracks in the fiberglass. How do I reinforce / repair this area. - Kevin
Rigsy is offline
post #2 of 5 Old 03-02-2013
Re: Repairing soft spot/indentation in Fiberglass sailboat hull -
It might be normal flex in the hull, aggravated by putting the wrong size pad in the wrong place. OR some of the glass fibers may have broken, no easy way to tell internally. Check out the West Systems web pages for articles on repairs and reinforcing.
hellosailor is offline
post #3 of 5 Old 03-02-2013
While afloat the support is uniform, unlike a poorly blocked boat on pads.. Not sure you need to worry too much beyond strategically placing pads near bulkheads the next time you haul, and/or put a bit more weight on the keel in the first place.
Faster is online now
post #4 of 5 Old 03-03-2013
tommays's Avatar
The boats weight always belongs on the keel the pads or cradle is just supposed to be balancing the boatb
You could pretty much dent any boat if support it wrong
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 5 Old 03-05-2013 Thread Starter
Thank you for your comments - you are most probably right - the pads on the cradle are supporting too much of the weight.
Kevin Rigg
Rigsy is offline
Cored deck soft spot repair sync Gear & Maintenance 80 08-01-2014 11:53 PM
Repair hull indentation/flat spot? jameswilson29 Gear & Maintenance 20 12-19-2011 01:48 PM
need help/info repairing fiberglass hull CanadianDave Gear & Maintenance 8 06-20-2011 01:33 PM
Found soft spot on hull after putting on trailer dflyin1 Gear & Maintenance 11 02-18-2008 11:37 PM
repairing keel - fiberglass cut trecksail Gear & Maintenance 13 02-17-2005 02:03 PM
