recommendations for halyard attachment?? - Page 2 - SailNet Community
 1Likes
post #11 of 29 Old 03-05-2013 Thread Starter
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: recommendations for halyard attachment??
as clarification.....
the shackle/splice issue is to attach the rope halyard to the wire halyard.. not the sail/s. Existing rig has/had snap shackles and HB shackle for attachment to head/s. Simply looking for advice on easy; but semi-permanent attachment of control lines.
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #12 of 29 Old 03-05-2013
"Sparkie"
j34035's Avatar
Originally Posted by genieskip View Post
I am slowly switching to soft shackles on my halyards as I get rid of the wire. They are easy to make and work great. Highly recommend them. I love the new cordage. This spring I will switch my lifelines to dyneema or amsteel.
Hey Genie! Good to hear from you! Have not seen anything from u in a while. How is the 40 working out for you?
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #13 of 29 Old 03-06-2013
mitiempo's Avatar
Paul
Why not go to all rope halyards? There is no good reason for wire halyards on a 27' boat - they are a leftover from the days when wire stretched less than rope.
Brian
mitiempo is online now
post #14 of 29 Old 03-06-2013
scratchee's Avatar
I'm in the same boat (heh) as the OP. If I were to switch to an all-rope halyard on my Cal 2-27, wouldn't I have to change the sheaves as well?
EDIT: Already been covered in other threads! (Short answer: probably.)
scratchee is offline
post #15 of 29 Old 03-06-2013 Thread Starter
deltaten's Avatar
No good reason???!!!!!!!
I take this to mean that there are alternatives today that didn't exist 30-some years ago.
Sure! I *could* spend untold dollars to change out a perfectly good system simply to update to new standards...but why?
I really do appreciate all the input; but throwing money at every issue is not an answer that I'm prepared to consider. I'm attempting to get on the water at the least possible (safe) price point. Other than replacing poor condition running rigging, [at this point in time] it seems everything else is in good shape. While I'd like..and may eventually end up replacing items, to upgrade and improve sailability, adding umptey-ump dollars worth of unnecessary goods and labor to an inexpensive boat would be foolish, as well as financially imprudent.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #16 of 29 Old 03-06-2013
Delta,
There absolutely are options today that didn't exist 30 years ago. Heck there are options that didn't exist five years ago.
To buy a wire to rope halyard with modern synthetics is both more expensive o. The front end, and more expensive life cycle cost than using modern line. And for the extra money the wire halyard gets you nothing beneficial. They are heavier, meat hook, rust, and have more stretch than dyneema will. All for a price premium.
Which is why no rigger I know even makes them any more. Sure there are probably a couple of shops that will, but for the most part it is a dead technology.
Greg
Stumble is offline
post #17 of 29 Old 03-06-2013
scratchee's Avatar
Originally Posted by Stumble View Post
Delta,
There absolutely are options today that didn't exist 30 years ago. Heck there are options that didn't exist five years ago...
I think what he meant was, just because there are new options available doesn't mean you have to replace the currently installed system that already works. I'm completely in tune with that sentiment.
That said, I discovered a meat hook on my main halyard, and that's why I'm considering a switch to a different system (all-rope,) given that I have to replace the halyard anyway. I also like the idea of just tying the halyard to the main, rather than using a shackle at all.
post #18 of 29 Old 03-06-2013
Generally, I think that if the new all rope halyard will actually fit over the sheave cleanly then there's no real need to worry about it, as long the the sheave is healthy and not binding.
Rope halyards tend to be very 'oversized' for the load, simply to make it easier to hold and handle them. Small wire-only sheaves usually won't accommodate the extra diameter. This occurs mostly on smaller boats that had wire/rope halyards connected by shackle and eye spice, where the rope section was never intended to go over the sheave.
If you currently have rope/wire spliced halyards, going to all rope should be no issue...
Faster is online now
post #19 of 29 Old 03-06-2013
mitiempo's Avatar
Maybe if the sheaves are for wire only. If they are for wire and rope they will have a groove for the wire as well as the normal curve for rope. Condition is an issue as well of course. After having wire running over them for several decades they may require replacement whether you are going to all rope or not.
If you want to get traditional wire/rope halyards properly spliced they are available. Splicing is the way to transition from rope to wire - spliced to a wire eye is a bit of a hack job really. Not real common unless the boat is quite large though. See this link:
Wilson Yates and Yates Custom Rigging
Brian
post #20 of 29 Old 03-06-2013 Thread Starter
deltaten's Avatar
Stumble;
The sail-end of the halyards is existing wire. All I need to do is attach new working/handling-end sheets. I priced the wire-to-rope replacement kits and all seem to run near to $120. Depending on type/brand...to replace wire with amsteel or dyneema and some other sort for the working end... stayset-x or VPC; I'd end up near the same..possibly a little cheaper
This is assuming that my head sheaves would run the synthetic without changing them out. For now, I plan on the handling-end change to a grade/type of line that , in the future, *may* be spliced to a synthetic. But that's all down the road
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
Halyard attachment. deniseO30 Gear & Maintenance 1 05-26-2011 10:05 AM
halyard shackle letting go, spinnaker halyard interference ctlow Gear & Maintenance 13 05-23-2011 10:55 AM
vang attachment bluwateronly Gear & Maintenance 3 01-27-2009 11:10 PM
8.3 Keel Attachment pnwardwell Columbia & Coronado 1 06-22-2008 02:32 AM
Forestay Attachment jkolle Gear & Maintenance 1 06-16-2006 05:56 AM
