recommendations for halyard attachment?? - SailNet Community
 1Likes
post #1 of 29 Old 03-03-2013 Thread Starter
deltaten's Avatar
Send a message via Yahoo to deltaten
I will be fitting new halyards to the W27 soon. Still not sure of mfgr or final size/type; but it's the attachment that wonders me.
Originals were 7/16 (?) double-braid, eye-spliced directly to the thimbled wire eye. I most certainly could go w/smaller dia. line, given newer loading specs on modern cordage.. would I want to?
Now, I can visualize sitting on the deck, splicing a line on; but why not use some sort of mechanical device; ie: snap hook, link or clip?
I *could* buy new halyards with a shackle already spliced on them; or conversely, do it myself in the comfort of my armchair or cabin. Would it be bad form to attach to the existing eye with a HB shackle?
Removeability option is open, due to the belief that I *may* wish to change out lines for some sort of utility use/reason.
Please recall that this is a limited budget production While I may eye the Dyneema. Vectran and T-900 lines; I doubt I really have need of that sort of load capability.VPC (?) would even be pushing it. seeing all the specs and sales on E-Bay causes page error flippin back and forth thru tabs! ta see what's what in comparison. As thrifty as I am; I'd sooner pay a bit more to go up-scale a degree than find out the "BrandX type I got quite up to my needed specs.
TIA,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #2 of 29 Old 03-03-2013
Re: recommendations for halyard attachment??
Tie them on.. using all rope, no heavy shackle flying about if you let go in a seaway, easy to shorten up or end-for-end if chafe is an issue, Bowlines if you have the vertical clearance and the knot won't interfere with the hoist, or the knot shown in the thread below if that won't work.
NO cost!!
Low profile main halyard knot
Faster is offline
post #3 of 29 Old 03-03-2013
NON member
AE28's Avatar
Faster…
I used the link you provided.
It looks like a figure-of-eight in the end of the halyard and then a single half-hitch on the headboard.
Is that all of it?
Thanks,
Paul
AE28 is offline
post #4 of 29 Old 03-03-2013
Well... My first thought would be one of our titanium D shackles...
For something stronger, lighter, and less money... Take a look at making up some soft shackles from short pieces of dyneema. Soft Shackles
Greg
Stumble is offline
post #5 of 29 Old 03-03-2013
Originally Posted by AE28 View Post
Fasterů
Is that all of it?
Thanks,
Paul
That's all of it. I like to leave the stopper with a couple of inches between it and the bight of the half hitch.. it avoids stressing/loading the stopper and makes things easier to untie. The halfhitch bight on the headboard takes the load, much like the turn of a bowline takes the load on that knot. I've never had difficulty untying that knot even after a hard days' sailing. I have had the stopper slide up to the headboard after a couple of reef/unreefs, but it's there primarily to prevent the half hitch from sliding free.
We've been using that knot for decades..
Faster is offline
post #6 of 29 Old 03-03-2013 Thread Starter
deltaten's Avatar
I kinda like the simple approach Faster As long as the bend doesn;t harm the line; I see noreasont to not use that hitch for halyards.
Interesting concept, those soft shackles. When I make my line purchase, I'll try t get a couple feet of Amsteel ta go with it. Then I can play with it at my leisure. Thanks for the tip, Stumble
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #7 of 29 Old 03-03-2013
I am slowly switching to soft shackles on my halyards as I get rid of the wire. They are easy to make and work great. Highly recommend them. I love the new cordage. This spring I will switch my lifelines to dyneema or amsteel.
genieskip
Northeast
J40
1991
genieskip is offline
post #8 of 29 Old 03-03-2013
pdqaltair's Avatar
Halyard knot. By the time you need to remove it, cut it off, which also moves the chafe point 6 inches.
The only reason for a shackle is if you remove the sail each time you sail.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #9 of 29 Old 03-04-2013
I don't discuss my member
zz4gta's Avatar
deltaten,
VPC from new england ropes makes great mid level halyards. Low stretch and not too pricey. You can use 5/16" at $1.00/ft for your 27 footer. Just shoot me an email. See sig.
I also make soft shackles in whatever size you need.
Edit: had to remove my sig due to the advertising policies of the site. I'm looking into sponsored advertising now.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #10 of 29 Old 03-05-2013
Break, curse, fix, repeat
bwindrope's Avatar
Well, the main reason I use a shackle is because I remove the halyard from the sail once it is down so that I can attach the halyard to a deck fitting on my pilothouse to avoid it banging on the mast. I'm one of those people who absolutely detests lines banging on a mast. I could do what Faster does and tie and untie the knot in both places, but the shackle is easier with no significant drawbacks in my experience. So I tied my new halyard onto my shackle with a buntline hitch, knowing it will tighten down and not come off, because I will not need to take it off until I may wish to swap ends of the line down the road.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
Halyard attachment. deniseO30 Gear & Maintenance 1 05-26-2011 11:05 AM
halyard shackle letting go, spinnaker halyard interference ctlow Gear & Maintenance 13 05-23-2011 11:55 AM
vang attachment bluwateronly Gear & Maintenance 3 01-28-2009 12:10 AM
8.3 Keel Attachment pnwardwell Columbia & Coronado 1 06-22-2008 03:32 AM
Forestay Attachment jkolle Gear & Maintenance 1 06-16-2006 06:56 AM
