mystery fitting - Page 2 - SailNet Community
 7Likes
post #11 of 22 Old 03-04-2013
Re: mystery fitting
I don't know, but it probably cost a thousand bucks, like everything else.
Jeanneau 54DS
Minnewaska is offline
post #12 of 22 Old 03-04-2013
Re: mystery fitting
It's for a stern line to the beach.
sony2000 is offline
post #13 of 22 Old 03-04-2013
Asleep at the wheel
jimgo's Avatar
Re: mystery fitting
Wow, I can't believe the "experts" here can't figure this out. That's an alternative attachment point for the backstay. Before they had backstay adjusters, you'd simply unhook the backstay and attach it down there instead. That would add additional rake to the mast, improving your downwind performance.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #14 of 22 Old 03-04-2013
Re: mystery fitting
... and then get out the repair kit when the backstay saws through the transom and deck...
Faster is offline
post #15 of 22 Old 03-04-2013
Asleep at the wheel
jimgo's Avatar
Re: mystery fitting
That's the beauty of this arrangement - progressive easing of the backstay as you finish up your downwind leg, and no need to loosen it as you begin to tack.
OK, sorry, I couldn't resist. I'm with the others, to my very novice eye, this looks like a handhold/step for MOB-like situations. I also agree that it needs some attention, and probably replacing.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #16 of 22 Old 03-04-2013
chef2sail's Avatar
Re: mystery fitting
At first I thought may attachemt point for a radar pole,...but not hole for cable. The maybe an attachement plate for dinghy towing, but why down there.
What ever it is the bolts holding it in are rusting pretty badly under the plate ( bet the plate and the bolts are two diferent metals) and really staining the hull.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #17 of 22 Old 03-04-2013
Learning the HARD way...
eherlihy's Avatar
Re: mystery fitting
It's a corrosion holder...
chef2sail likes this.
eherlihy is offline
post #18 of 22 Old 03-04-2013
Re: mystery fitting
That's it!
Tymadman is offline
post #19 of 22 Old 03-04-2013
Re: mystery fitting
Any other odd fittings near the stern? Maybe it is one part of a system for something. Can't figure out how one dinghy davit attachment helps but....
If it is a step it is not a useful one for climbing out of the water.
KBuckley is offline
post #20 of 22 Old 03-04-2013
davidpm's Avatar
Re: mystery fitting
Take if off clean and fill the holes. Patch the gel-coat.
Guaranteed 15 minutes later you will find out exactly what it is for and why it is critical.
davidpm is offline
pump out fitting TBG P30 2 07-14-2012 08:38 PM
What is this fitting? davidpm Gear & Maintenance 12 05-06-2010 05:16 PM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
Name that fitting... cghubbell Gear & Maintenance 12 08-28-2009 08:13 AM
Ten Lessons of Fitting Out Micca Hutchins Her Sailnet Articles 0 03-14-2001 07:00 PM
