mystery fitting - SailNet Community
 7Likes
post #1 of 22 Old 03-03-2013 Thread Starter
flo617's Avatar
mystery fitting
I have a mysterious fitting installed on the stern of my boat.
Would anyone know what it is there for?
Thanks
Florent
flo617 is offline
post #2 of 22 Old 03-03-2013
Re: mystery fitting
It is intended to be load bearing, but the angle is not good for a step. Is there anything above it? What kind of boat? Was it set up for crossing oceans?
In other words, I don't know.
ccriders is offline
post #3 of 22 Old 03-03-2013
Re: mystery fitting
Probably a step. In Canada they have made a means of boarding a boat from the water, mandatory equipment. I weld similar, but better braced such steps on my skegs and transoms, for boarding when the boarding ladder is not down.
Brent Swain is offline
post #4 of 22 Old 03-03-2013
Re: mystery fitting
With that little strut support there it must have been intended to hold some wieght.
A toe hold to help climbing out of the water?? but then I'd expect to see a couple more on the way up (though they could have hung a piece of rope over the transom.... a handhold for when you're cleaning the rudder while swimming?
Skookum fitting in an odd place otherwise..
Faster is offline
post #5 of 22 Old 03-03-2013
Re: mystery fitting
Cheap POS for a step. I'm thinking a PO just screwed in whatever looked like it could be used as a towing eye, for towing a small dink. Or at least, tying up as they came astern. Either way, the rust tells you it needs to be pulled.
msmith10 and groggy like this.
hellosailor is offline
post #6 of 22 Old 03-03-2013
rugosa's Avatar
Re: mystery fitting
Is there a hole or similar fitting on the rudder? Could be cable or chain attachment in case rudder drops.
rugosa is offline
post #7 of 22 Old 03-03-2013
Wish I never found SN!
SimonV's Avatar
Re: mystery fitting
I will go with emergency step. One would be all you should need to haul yourself up and out. That bit of rope with the knot, is that attached to the pushpit rail, if so may be part of the set up. Simple and effective.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #8 of 22 Old 03-03-2013 Thread Starter
flo617's Avatar
Re: mystery fitting
Great inputs everyone, thanks.
One piece of info though, the rope has nothing to do with the setup, it's just some stuff I attached there for the haulout.
flo617 is offline
post #9 of 22 Old 03-04-2013
Tartan 27' owner
CalebD's Avatar
Re: mystery fitting
Could it have been put there to support the bottom of some kind of swim ladder?
Everybody has one:
CalebD is offline
post #10 of 22 Old 03-04-2013
Dinghy tow point?
Tymadman is offline
pump out fitting TBG P30 2 07-14-2012 08:38 PM
What is this fitting? davidpm Gear & Maintenance 12 05-06-2010 05:16 PM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
Name that fitting... cghubbell Gear & Maintenance 12 08-28-2009 08:13 AM
Ten Lessons of Fitting Out Micca Hutchins Her Sailnet Articles 0 03-14-2001 07:00 PM
