Cracked potti repair? - SailNet Community
 6Likes
  • 5 Post By chucklesR
  • 1 Post By Minnewaska
post #1 of 8 Old 03-03-2013 Thread Starter
rbyham's Avatar
Found a 1" cracked in bottom of domestic sanipotti. What should I use to repair it?
rbyham is offline
post #2 of 8 Old 03-03-2013
chucklesR's Avatar
Re: Cracked potti repair?
A new potti
chucklesR is offline
post #3 of 8 Old 03-04-2013
Irrationally Exuberant
Originally Posted by chucklesR View Post
A new potti
That's defnintely the fix I would do.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #4 of 8 Old 03-04-2013
Tartan 27' owner
CalebD's Avatar
You don't really want to have to repair that twice. Could be a pretty sh!tty mess.
The Jabsco manual heads are cheap: Jabsco Twist 'n' Lock Manual Toilet
Many folks just buy a new one when the old one wears out after several years.
Groco and Raritan make better heads but cost more at the outset.
Everybody has one:
CalebD is offline
post #5 of 8 Old 03-04-2013
overbored's Avatar
Sanipottie permanent? buy a new one. they are about $ 150
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 8 Old 03-04-2013
Just last season, I did my last potti repairs ever (I hope). We have electric heads and one was leaking at the macerator and another was not pumping correctly. It was filthy and cost an entire weekend. Hours of crawling around to remove little screws I could not see but had to do by feel.
I was talking to one of the yard guys about it and he said they will not take a job to fix one. It would cost more than just bolting a new one on. He started his reply by saying, "your time must not be worth much". His point was right on.
rugosa likes this.
Jeanneau 54DS
Minnewaska is offline
post #7 of 8 Old 03-04-2013 Thread Starter
rbyham's Avatar
Thanks folks. I hear u on replacing this with new. I may just dothat . However it being a non-holding tank portable toilet in otherwise great shape I may go for something cheap like eyernabond yape or just a quick glass repair kit. Call me cheap which I am but it is at least worth a try. My other thought is down the road to plumb it in for pump out capability. I think it is a domestic 975msd.
rbyham is offline
post #8 of 8 Old 03-04-2013
Old enough to know better
Before I used some sort of tape (assuming that is what you are talking about above) think I would use some sort of 2 part epoxy like JB weld. If this is any part of the system that holds fluid, I would just replace it. But if it is just the outer shell then I might try patching it for a few seasons. I would not expect tape to do much though, especially if it is part that holds fluid. that is a fluid that you do not want to leak! porti potties are worse even that regular heads with that blue fluid, and waste.
miatapaul is offline
What is so bad about a Porta Potti? rhr1956 General Discussion (sailing related) 34 02-21-2013 12:02 AM
Chaninging from Porta-Potti to pump out cb32863 Gear & Maintenance 13 06-01-2012 02:58 AM
PORTA POTTI - A 'no no' or 'okay' for cruising? SailMonkey General Discussion (sailing related) 44 05-31-2012 11:23 AM
Repair Cracked Teak Toe Rail casey1999 Gear & Maintenance 15 02-04-2011 10:52 AM
plexiglass cracked dome repair anadem Gear & Maintenance 7 10-27-2007 10:54 AM
