Mast Blocking - SailNet Community
 2Likes
  • 1 Post By svHyLyte
  • 1 Post By Sanduskysailor
post #1 of 8 Old 03-04-2013 Thread Starter
Mast Blocking
Currently I have wedges of wood which I use to block my mast, the current setup is not working to well, the wedges pop out over time. I was thinking of cutting a T shape out of wood to block the mast in place but I am curious about how other people do it. Pictures would be helpful if possible.
Thank you for you help.
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #2 of 8 Old 03-04-2013
Re: Mast Blocking
I replaced the wood wedges with some rubber plates I got from my rigger.
He stocks them in different thicknesses.
One piece on the aft section of the mast
Pull the mast backwards in the hole and insert the on in the front (tight fit)
The two pieces are so wide that I don't need any at the sides.
No more problem with wedges popping out
knuterikt is online now
post #3 of 8 Old 03-04-2013
Old as Dirt!
svHyLyte's Avatar
Re: Mast Blocking
See (click on) Spartite
Seaduction likes this.
svHyLyte is offline
post #4 of 8 Old 03-04-2013
Senior Moment Member
SloopJonB's Avatar
Re: Mast Blocking
Hard rubber wedges were the standard specified by S&S. Spartite looks like a high tech version of same with the added benefit of sealing the deck opening.
SloopJonB is offline
post #5 of 8 Old 03-04-2013
tommays's Avatar
Re: Mast Blocking
Spartite kit for sure one time and it pretty much lasts forever
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 8 Old 03-04-2013
Re: Mast Blocking
My sail maker stocks these. CR Marine Rubber Mast Chock - Custom Rubber Corp.
A lot easier to use than Spartite plus you can change them if you want to change your mast rake.
msmith10 likes this.
Sanduskysailor is offline
post #7 of 8 Old 03-05-2013
ebs001's Avatar
Re: Mast Blocking
I installed Spartite in January and have sailed to the Bahamas. So far I am very happy with installation. Not only does it do an excellent job of blocking the mast but we no longer get water, not even a drop, coming in around the mast.
I actually bought too much and have basically a small kit left over which I am willing to sell. If interested PM me although it's in Brunswick, Ga and I wont be back there until the end of April.
ebs001 is offline
post #8 of 8 Old 03-05-2013
chef2sail's Avatar
Re: Mast Blocking
I am with Sandusky Sailor and use these in conjection with a mast collar (boot). Zero leackage down the mast
SAIL SYSTEMS Universal Mast Boot at West Marine
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Deputies: 30-foot sailboat falls from trailer, blocking bridge - ABC NEWS 4 NewsReader News Feeds 0 02-02-2013 07:10 AM
WTF! - Adware blocking Sailnet, DO NOT CLICK JimMcGee Announcements and Suggestions Box 33 10-06-2010 07:13 AM
Suggestion box -- ads blocking botton choices Bene505 Announcements and Suggestions Box 5 08-15-2010 07:42 AM
Sailboat Blocking I-85 - WRAL.com NewsReader News Feeds 0 05-27-2007 05:15 PM
Jacking up/blocking Catalina 22 texfar Gear & Maintenance 0 07-24-2002 04:24 PM
