Where does this go...? - Page 2 - SailNet Community
 2Likes
post #11 of 23 Old 03-05-2013
Asleep at the wheel
jimgo's Avatar
Re: Where does this go...?
Why not reuse it as a topping lift adjuster?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #12 of 23 Old 03-05-2013 Thread Starter
Superior Sailor
Squidd's Avatar
I'm thinking clean it up change the line and give it a try as topping lift adjuster...
A. wanted to be sure it didn't serve a better purpose somewhere else...
B. wasn't sure adjustability was neccessary in topping lift, but I'm not thrilled with detaching the TL when sail is up (secure to mast) and then having to return TL to boom to let sail down...so that should cover both issues...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #13 of 23 Old 03-05-2013
Not the best looking line but it could be a fine tune for the mainsheet.
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #14 of 23 Old 03-05-2013
An adjustable TL allows you to ease it when hoisted, reducing leech chafe, and also allows you to tension the TL in very light air to support the weight of the boom, which will otherwise close the leech.
And, in the cockpit with the rum out you can raise the boom out of your way a bit more...
Faster is offline
post #15 of 23 Old 03-05-2013 Thread Starter
Superior Sailor
Squidd's Avatar
I think we may have found a use for it...!!
Cleaned it up added new line...Gonna use it for TL adjustment and eliminate having to r&r TL every time the sail goes up/down...
"Captin Ron"
Squidd is offline
post #16 of 23 Old 03-05-2013
Asleep at the wheel
jimgo's Avatar
That was on my "to do" list for my old boat. I think you'll see a lot of advantages once it is set up. Enjoy!!!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #17 of 23 Old 03-07-2013 Thread Starter
Superior Sailor
Squidd's Avatar
Final version...lost the fiddle block lighten up the whole rig and use as TL adjuster...
This way I still have the jam function on the lower block without the weight overhead of the fiddle block
"Captin Ron"
Squidd is offline
post #18 of 23 Old 03-07-2013
Tim R.'s Avatar
What is the black electrical tape for?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #19 of 23 Old 03-07-2013 Thread Starter
Superior Sailor
Squidd's Avatar
I cross stiched and whipped the loop with whipping twine, normally I would have a piece of shrink wrap on there but grabbed tape cause I was "lazy"...
"Captin Ron"
Squidd is offline
post #20 of 23 Old 03-07-2013
HANUMAN
RobGallagher's Avatar
I had a similar set up for my topping lift and put a snap shackle on the end and longer line so I could disconnect if from the boom and get it out of the way.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
