Micron CSC vs Micron Extra --- Mid-Chesapeake - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 03-05-2013
blt2ski's Avatar
Re: Micron CSC vs Micron Extra --- Mid-Chesapeake
Having used Micron the last two times, that is all previous owner used for 20 yrs. I used WM PCA 2 yrs ago, held up well, did not have as much junk on it. Could have gone a third year in water all year in puget sound. But had to pull a month ago for a leaking PSS shaft seal. Boat was out, so on went another coat.
The PCA seems to ablate easier and better per say than the Micron did, and at slower speeds. Probably a softer paint too, so it may not be as good per say.......but getting a clean bottom after sitting for 2 months on news years day after a 1-2 hr sail.....can not complain. It was after that new years sail I cam back to the boat and found water over the floor boards and a slow leak in the shaft seal.
I do not recall who said it, but some ablatives are softer, and only need 2-4 knots of speed to clean themselves. Where as the Micron IIRC needed 5-6 knots to start to ablate. So if you have a 6.5knot hull speed boat, the softer could be better.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #12 of 16 Old 03-06-2013
Walter
I use Blue Water ablative 45% copper and get one year of a very clean bottom, no paint build up to sand and only pay $120.00 per gallon at Old Bay Marina on Old Road Bay off of the Patapsco. Blue Water anti-fouling is rated close to #1 in all the sailing and powerboat magazine tests.
If you want to get 2 years or more, they have a 65% copper, but I haul-out at the marina very winter so that I do not have to worry about the boat bouncing around during those winter storms.
I have Old Bay Marina paint my Catalina 30 bottom, the labor including tape, brushes, rollers, and supplies is $195.00 and they use about 5 quarts of bottom paint but still only charge me for one gallon at $120.00 per gallon. Best prices on the Chesapeake and they do a nice job for what a lot of you guys are spending for just the paint alone. $315.00 for paint and labor on my Catalina 30!
I also have them give my prop a coat of PropSpeed and and I never need for a driver to go down mid-season and clean my prop. When I had the driver clean the prope it just fouled up again after a few weeks and was just a waste of my money. With the PropSpeed coating the prop stays clean, it is the only thing that works and stays on the prop until the end of the season.
My marina charges me $175.00 for the PropSpeed and labor - not bad considering two small cans of the stuff (smaller than a cat food can) at West Marine is about $300.00. Old Bay can do two sailboat props with one kit. They buy/use so much PropSpeed that they must get a good discount, so its cheaper for me to let them do the application.
walterzoy is offline
post #13 of 16 Old 03-06-2013 Thread Starter
pdqaltair's Avatar
Threads always drift.
I've not heard a lot of Chesapeake area discussion of Bluewater, their 40 and 60% Cu paints are always rated highly, and they're cheap. Less marketing budget?
The other thing is that paint test programs by magazines never include any scrubbing. Since most owners do scrub at least a little, I wish they would. I find myself wondering if the Pettit Ultima holds up as well to that as the Interlux Micron.
I guess I could flip a coin and not know the difference.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #14 of 16 Old 03-06-2013
I've had good luck with the Bluewater ablative product line too. I can get at least 2 years and sometime even 3 years between haul outs with the boat having been located in the Annapolis area. Prior to using the Bluewater I've used numerous other brands of ablatives over the life of the boat(28 years) and have quite a build up of paint over those years even with frequent use and also a good scrubbing whenever hauled out. Now the boat is getting a new barrier coat(it had a coal tar barrier coat put on back when the boat was new) and I'm considering useing the Micron Extra since I'm using the Interlux product line on the barrier coats. Need to consider some of the other ablatives from Interlux however if there remains a significant price differance between Interlux and Bluewater....I'll go back with the bluewater since hot coating can be achieved with either regardless of brand.
lancelot9898 is offline
post #15 of 16 Old 03-06-2013
chef2sail's Avatar
Old Bay Marina has good prices as does Youngs where I get mine done. Guess thats because they are close to each other. A friend of mine keeps his boat in Old Bay. I also use the petit product on my prop
I find its easier on the rig that the boats in the water, covered for the winter
where when the wind blows the boat can give instead of vibrating in jack stands. Our club has good protection and my slip is 11 ft deep so no danger of bottoming. Boats are better supported by water than 8 jackstands placed under them. Beside I pay for a slip year round and save on having the boat hauled and blocked which in your case would add $15/ ft or $450 per year to the price.
Right now you can get UltimaSR60 from Defender for $188 a can or a cost of $68 more, however it lasts at least 2 years. I am on my third year with it. If you add in $100 a year for the diver and look at a two year analysis it looks like this.
2 haul outs ( $900)+2 cans of paint ($240)+2 labor and supplies( $390)= $1540 for two years
vs
1 haul out ($450)+ 2 diver($100)+ 2 cans of paint ($288) + labor and supplies ($195)= $1133
Thats a savings of $400 by using the the paint that lasts for two years and also having a diver clean the boat twice each season. If you can get a third year out of it like I will this year by using this paint which seems to perform really well., I will actually save another $770 and also the wear and tear and stress o the boat having it lifted/
I suppose if I took the boat of the water you could put almost any ablative on it as I think in the PS tests all did well the first year.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #16 of 16 Old 03-06-2013
chucklesR's Avatar
I was spoiled with my Gemini, I could put it in 3 feet of water and walk around it scrubbing the bottom (or pay a kid to do it, buck a foot). I used hard paint, so scrubbing was not a problem.
Now I've got to pay attention to this thread.
chef2sail likes this.
chucklesR is offline
Micron 66 spirit54 Gear & Maintenance 23 11-08-2013 12:13 AM
Bottom paint: Micron Extra/CSC, Pettit Ultima SR-40/SR-60 dreuge Gear & Maintenance 57 06-24-2013 06:38 AM
Interlux Micron 66 Failed in the Chesapeake BigMoe Gear & Maintenance 8 03-09-2012 09:17 PM
Anyone need a gallon of Micron Extra with Biolux - Blue? Bene505 Gear & Maintenance 2 05-06-2010 09:49 AM
Micron Extra vs. Micron CSC vs. Petit ??? CLucas Gear & Maintenance 18 03-28-2010 07:23 PM
