The last 3ft (mast work) - Page 2 - SailNet Community
 10Likes
post #11 of 22 Old 03-07-2013
Courtney the Dancer
jrd22's Avatar
Re: The last 3ft (mast work)
I've seen where just two equal-level mast steps have been installed 4-5 feet below the truck so that the person up there has real solid footing and a good height to work on things at the masthead..
Avoids the run of steps all along the mast, and puts less load on the chair, lines, etc once you're 'up there'.. a telephone linesman's waist strap will improve the setup even more..
This is exactly the set up we have. It's very difficult to get up high enough with either a bosuns chair or a harness to be able to work on lights etc on top of the mast. With the two steps and a strap to hold you close to the mast it makes it a lot easier, and safer.
Faster likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #12 of 22 Old 03-07-2013
Must be where I'd seen it before!
Faster is online now
post #13 of 22 Old 03-07-2013 Thread Starter
One of None
deniseO30's Avatar
Thanks everyone for the input! I really need the mast down on the ground someday.
ck this one out.
My last project!
deniseO30 is offline
post #14 of 22 Old 03-07-2013
Just one of the many reasons I love using the gin pole at a nearby marina/yacht-club. Costs $20 for use for non-members, but well worth it since I can get a good 4-5 feet above the top of my mast if I ever needed to. The powered two-way winch is another nice feature.
SolSailor is offline
post #15 of 22 Old 03-07-2013
remetau's Avatar
I have an ATN and had the same issues. I finally installed some folding steps.
I suggest what another poster says to install two steps at the top to stand on while working.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #16 of 22 Old 03-07-2013 Thread Starter
One of None
deniseO30's Avatar
Yeah.. I"m in a YC too and have one club down river with a crane..
And how tall is your mast sol?
My last project!
post #17 of 22 Old 03-09-2013
ck this one out. How To Build & Use "The Easy Climb" - A Mast Climbing Aid - YouTube
This unit appears to work on the same principle as the ATN, except an assistant is needed. That is because of the camcleat not being reliable to hold the weight. If you're afraid of climbing alone, I suppose an assistant with an ATN should work well. I use a short strap on the ATN harness to get up as high as possible, but then have to stand in the stirrups. I then tie a line around me and the mast, like a lineman, to free up both hands. Doesn't feel secure, but I think it actually is.
Also, I use a designated line to climb on, thus eliminating tying any knots to a halyard. This allows me to get at least 8" or more higher.
Marc
gershel is offline
post #18 of 22 Old 03-09-2013
Wish I never found SN!
SimonV's Avatar
Mast steps are beginning to look better and better the older I get.
jrd22 likes this.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #19 of 22 Old 03-10-2013
baDumbumbum
bobmcgov's Avatar
You can jack yourself a good 4' above the masthead with just a climbing harness, standard or improvised aiders (webbing steps), and a short sling. It's scary at first and requires major core strength to do it for long. I've worked that way for about two hours, replacing wifi antennas on a tower top. Leaves you wasted. But you can reach that high, if needs must. Top-stepping demo HERE.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #20 of 22 Old 03-10-2013
You really think this would work for someone who is old, fat, bald, and ugly? Not to mention scared. ROTFLMAO
Marc
MarkofSeaLife likes this.
gershel is offline
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 02:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 11:05 AM
tool recommendations for fiberglass, mast work LookingForCruiser Gear & Maintenance 2 06-10-2009 11:56 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 04:11 PM
How does self a raising mast work danjarch General Discussion (sailing related) 3 08-13-2007 11:42 AM
