Like Tree10Likes
  #1
Old 03-06-2013
deniseO30's Avatar
Lies about her age
The last 3ft (mast work)
Last year, my good buddy Hank tried to get to the top of my mast with the ATN climber. He did get up there to inspect things But for some reason he could not get high enough to see and work on the top of the masthead. Is this a common problem with getting up there using ATN and Bosun's chairs?
Note; he's over 6ft tall.
jsnaulty likes this.
  #2
Old 03-06-2013
marcusc130's Avatar
marcusc130 is on a distinguished road
Shouldn't be a problem. But you do have to stand up in the foot straps and kind of get up out of the seat to get over the mast head. The last few feet can be tough because the ascenders on the ATN rig tend to be right up against the mast at that point, and hard to manipulate. You really need to use the rigging to take your weight off the harness to move up high enough to get over the masthead.
  #3
Old 03-06-2013
misfits is on a distinguished road
Re: The last 3ft (mast work)
Maybe I'm just getting old but that's the one area of the DIY arena, I'll gladly part with the cash.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
  #4
Old 03-06-2013
CaseyB is on a distinguished road
I use the ATN and have to stand in the stirrups to do masthead work. Shouldn't be a problem unless the person doing the work is less than 5 feet tall.
  #5
Old 03-06-2013
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
What Casey said.
Regards,
Brad
Fun fact #2484: In my avatar, that's DavidPM at the helm of my boat.
  #6
Old 03-06-2013
I've seen where just two equal-level mast steps have been installed 4-5 feet below the truck so that the person up there has real solid footing and a good height to work on things at the masthead..
Avoids the run of steps all along the mast, and puts less load on the chair, lines, etc once you're 'up there'.. a telephone linesman's waist strap will improve the setup even more..
  #7
Old 03-06-2013
Lake Superior Sailor's Avatar
Lake Superior Sailor is on a distinguished road
Build a crows nest, stick around a while!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
  #8
Old 03-07-2013
celenoglu's Avatar
celenoglu is on a distinguished road
You can shorten the line from the bosuns chair to the ascender. This way you will be much higher. I am not sure if it is possible with ATN climber. I am currently using Petzl ascenders and 3/8 rope.
  #9
Old 03-07-2013
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
This is a common issue with the ATN if you want to sit in it and work. Just can't get up high enough. I use a climbing harness and can get a bit higher than the ATN.
Merit 25 # 764 "Audrey"
  #10
Old 03-07-2013
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Getting above the top of the mast can be tricky... Even trickier is doing it while not holding on so you can use a drill, tools, screws etc etc etc
And remember the average cruiser is a rank amature with tools in a workshop on terra firma so fumbling at the mast head can be a slow, frustrating and dangerous process. Dangerous for the poor mug on the deck too! One of my idiot mates who "loves" heights and is about 30 years old went up on his ATN mast climber, dropped a drill battery nearly on my head, bent the bloody toe rail and then ran out of energy to climb the ATN gizmo down!
I try to pay someone who is competant to do jobs up there. Though I will go up and do my own checks, etc.
Remember this: if you spent your whole life behind a desk and are now going cruising remind yourself of Dirty Harry "A mans gotta know his limitations"
Mark
Faster and oysterman23 like this.
Sea Life
Notes on a Circumnavigation:
I write with an iPad and its spell checker changes some words. Beware.
You may post attachments
You may edit your posts
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
tool recommendations for fiberglass, mast work LookingForCruiser Gear & Maintenance 2 06-10-2009 10:56 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
How does self a raising mast work danjarch General Discussion (sailing related) 3 08-13-2007 10:42 AM
SEO by vBSEO 3.6.1
