4 Stroke Outboard-Annual Service-Fresh Water Only - SailNet Community
post #1 of 4 Old 03-06-2013 Thread Starter
rhr1956's Avatar
What is on your list each year when getting your outboard ready for the season? Fresh water users only please.
rhr1956 is offline
post #2 of 4 Old 03-06-2013
tommays's Avatar
Re: 4 Stroke Outboard-Annual Service-Fresh Water Only
There is really NO differance all the things like changing the lower unit oil should be done in the fall to spot any issues while they are small
Same thing for draining the fuel
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 4 Old 03-06-2013
Thorough visual inspection, new oil & plugs. Maybe every other year, new lower unit oil.
Lube appropriate fittings, fresh fuel, check prop nut, wipe off the dust and go.
The owner's manual should have all the details.
Paul T
dabnis is offline
post #4 of 4 Old 03-06-2013
Solina 27
Sternik's Avatar
My usual excuse to play in the garage includes:
- change engine oil
- change lower unit oil
- change fuel filter
- change plugs
- general visual inspection
- add fuel stabiliser to the last tank of gasoline for the season
- clean, shine and enjoy :-)
Sternik is offline
johnson 3.3hp outboard 2-stroke q's Incantation Gear & Maintenance 12 04-16-2011 06:59 PM
No Name 2 HP 2 Stroke Outboard eherlihy Gear & Maintenance 17 04-03-2011 08:49 PM
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 06:15 PM
6 vs 8 hp four stroke outboard slimpicknns Introduce Yourself 3 06-27-2009 06:50 PM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
