Cam cleat placement for jib sheets? - Page 3 - SailNet Community
 14Likes
post #21 of 48 Old 03-07-2013
rhr1956's Avatar
Re: Cam cleat placement for jib sheets?
Mine is done like Faster's diagram except that I mounted the cam cleat directly vertical under the tail end of the sheet where it comes off the winch. They work great and the sheet pops right out when you need it too.
rhr1956 is offline
post #22 of 48 Old 03-07-2013
rhr1956's Avatar
Originally Posted by itsaboat View Post
My boat has horn cleats for the jib sheets but I am going to install cam cleats for ease and speed of tacking and trimming. I purchased a couple of Harken Cam-Matic 150s to install, but am not sure exactly where I want to put them. I don't want to remove the horn cleats, since that is how we attach the aft dock lines and might need them for many other reasons. However, that makes space to install the cam cleats a little tight. My main options seem to be 1) installing them between the winches and the horn cleats, creating a potentially tight situation or 2) or vertically on the coaming at a location that will not interfere with cockpit seating.
I attached a couple of photos to illustrate the situation. Any suggestions?
Put the cleat right about here...
rhr1956 is offline
post #23 of 48 Old 03-07-2013
Irunbird's Avatar
Originally Posted by msmith10 View Post
The best solution, also most expensive, is to get self tailers. Beyond that, I think you're better off with the horn cleats you've got. I used them with same setup as yours for many years. The advantage to a horn over a cam cleat is that you don't have to "pull through" the cleat. You just hook the line under the horn and the tension is off. With a cam, you've got to take "one more turn" with the winch as you're pulling the line through the cam. Sometimes that "one more turn" just isn't there. Also, releasing a short length of sheet in order to trim is much easier with your existing cleats.
I think you'll have trouble getting a clean lead from the winch to the cleat on the side of the combing- it's going to rub.
Also, pulling down through that cam is a terrible angle to get any force.
Personally, I'd keep your current cleats in place and save up for self tailers.
Or you could do both. It is definitely expensive (about $800 for both winches in my case, and both were upgradable). We had the cam cleats working for a while, but I replaced the winch top with self-tailing tops to make it easier while singlehanding. When I race with crew, they almost always prefer the simplicity of the cam cleats. Also- if you do much singlehanding, you may consider cross-sheeting, which would probably mean (besides just longer sheets, maybe) placing the cleats on the horizontal surface next to your winches. In that case, angle would be less important since the sheet would be running across the cockpit.. It would be a bit difficult to achieve tight trim because you'd be tailing from across the cockpit and would have to grind with one hand while tailing with the other...
Irunbird is offline
post #24 of 48 Old 03-07-2013
blutoyz's Avatar
Yes, the 84-85 Pearson 27 was the same mold as the '81-83 US27 from what I can gather. Pearson bought it and made a couple of dozen at least (my hull is #24) over a couple of years. In 86 they switched to another design and still called it the P27 just to add to the confusion. Here is the thread I started when I first bought her: First and new (to us) boat! 1985 Pearson 27 Hull #24
There is one other US27 sailor on here, US27inKS, or something like that.
Have you upgraded any of the hardware on your boat? The horn cleats behind the wheel are just a little inconvenient to me but I am not ready to drop $1800 on self tailing winches yet. I would rather put that money into new sails.
This will be the first season so no upgrades planned until I know what needs doing. This was bought as a "first" boat so I don't know if it will get any real upgrades anyhow. You never know though, the PO was so in love with the handling I may stay with her long enough to throw some dough into updates.
I do plan on lazyjacks, sternrail seats, and possibly a main halyard relocate with clutches prior to launch in May.
Thanks for the link, I will check out your original post.
Bill
blutoyz is offline
post #25 of 48 Old 03-07-2013
fallard's Avatar
I've moved on from a rather spartan catboat to a bigger boat with lots of bells and whistles (and self-tailing winches). For many years, though, I was a real Luddite for the 15 years I owned the catboat. ("Luddite" sounds better than "frugal" and a whole lot better than "cheap".)
The mainsheet attached to the 19 ft boom on the catboat was stopped around a horn cleat. No winch. Did that for 15 years and never considered anything fancier. We raced her for years and did a lot of fine tuning of the sail trim, too, so the bronze cleat stayed polished.
Looking at the photos, I don't see a compelling need to upgrade your hardware if you are not so inclined. About the only "hardware" I added to my catboat was lazyjacks--and that was after getting caught in 30 kts and wondering how I could conveniently drop everything, including the 14 ft gaff, and keep the sail and me in the boat.
jwing likes this.
fallard is offline
post #26 of 48 Old 03-07-2013 Thread Starter
itsaboat's Avatar
Thanks rhr. I am leaning toward this config right now. The port side cam will have to be positioned forward of the winch to keep the proper angle, of course. I'll head out to the boat Saturday (or tomorrow if I can manage to blow a vacation day) and dry fit the cam cleats to see how I like it.
I was approaching this from the angle of passenger comfort at first, but realized that was all wrong after Faster's helpful comments. If I install a cam cleat at a position that discourages sitting there, maybe I can finally stop having to ask someone to move their derrière from in front of the $#@% winch every time we tack.
Pearson 27
itsaboat is offline
post #27 of 48 Old 03-07-2013
Carrying the wrap around like my initial picture showed will lead the port sheet to aft of the winch.. Pretty much where you're at in the pic above... Should work fine..
Faster is offline
post #28 of 48 Old 03-07-2013
No more curry buffets
Ritchard's Avatar
I thought about clam cleats. The boat that I crew on racing Sundays has them. They work well, but the heel of my hand is always sore on Mondays from giving them a thump to make sure the line is seated. Probably unnecessary, but I can't help myself.
I usually quickly press the line into the cleat with the tips of two fingers, then let the tension do its thing. If you feel compelled to thump the line into the clamcleat, maybe the cleat is undersized? My 9/16ths sheets fit easily and snugly into the very bottom of the cleat. I sailed the boat at least 60 outings/days last year, and had no slips when I was winching. Newcomers would often goof it up, but we feed them to the salmon.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #29 of 48 Old 04-28-2015
Hi Itsaboat
What did you finally do and is it working out? I am in the same, er, boat and appreciate your having asked the question. I am thinking that, as with a rope clutch, you need to take the load off before coming out of the cam cleat. Currently I can jam the tail on the horn cleat after one wrap. But I am not so good at flipping that off and not losing the tension.
Sterilecuckoo58
'70 Vivacity 24
Sterilecuckoo58
Vivacity 24 twin keel
Johnson O/B 9.9
sterilecuckoo58 is offline
post #30 of 48 Old 04-28-2015
rhr1956's Avatar
Originally Posted by sterilecuckoo58 View Post
Hi Itsaboat
Sterilecuckoo58
'70 Vivacity 24
I'm not sure what you mean regarding "taking the load off before coming out of the cam cleat". I just pop the sheet out of the cleat and take the wraps off the winch when tacking. Takes about 1 second.
rhr1956 is offline
Jam cleat on the jib Sublime General Discussion (sailing related) 5 05-28-2011 09:18 PM
Another way to cleat davidpm General Discussion (sailing related) 16 09-25-2009 04:27 PM
looking for a cleat MtHopeBay Gear & Maintenance 12 05-23-2009 02:38 PM
Changing a V-Cleat to a C-Cleat? funjohnson Sailboat Design and Construction 11 08-21-2008 11:14 AM
Cleat?? sailboter97 Gear & Maintenance 4 04-08-2002 06:25 AM
