How to avoid dark areas when varnishing teak? - SailNet Community
 3Likes
  • 1 Post By mike dryver
  • 1 Post By Minnewaska
post #1 of 6 Old 03-07-2013 Thread Starter
I need to add a few layers of varnish to my toerails. Most of the existing varnish is sound and will be lightly sanded. On some small areas the varnish had lifted, so I removed the loose stuff with a carbide scraper, leaving some areas down to bare teak.
In the past I've found that, where the varnish is applied onto bare teak, the wood will turn much darker than elsewhere.
Is there a way to avoid these dark patches where the bare wood was, and get a uniform appearance?
MarkSF is offline
post #2 of 6 Old 03-07-2013
Re: How to avoid dark areas when varnishing teak?
Mark try a little TSP in solution. It should take the discoloration out, and lighten the area. you just have to rinse real well and dry after
msmith10 likes this.
mike dryver is offline
post #3 of 6 Old 03-08-2013
Are you sure you aren't just noticing the difference between varying thicknesses of varnish? As you build the varnish layers, the thicker gloss layer can make it appear lighter, even though the wood below it isn't.
SloopJonB likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 6 Old 03-09-2013 Thread Starter
Not sure really...I've got some TSP though so we'll see what happens
MarkSF is offline
post #5 of 6 Old 03-09-2013
If you scraped right down to bare wood, you may have burnished the grain and kept it from soaking the first coat. Best to hit it with some sandpaper and be sure that first coat is highly thinned out. You might even just prime all the bare spots with 50/50 first, followed by a couple of layers of 25%, then go back and sand everything out as even as you can get it, before starting to build.
BELLATRIX1965 likes this.
Jeanneau 54DS
post #6 of 6 Old 03-09-2013
Maine Member
BELLATRIX1965's Avatar
Exactly what Minne said - I do that all the time with my teak toerails!
BELLATRIX1965 is offline
Dark dull interior teak dorksian Gear & Maintenance 14 10-12-2011 11:10 PM
Cleaning dark teak bulkheads Guidera48 Gear & Maintenance 2 07-19-2009 06:55 PM
varnishing oiled teak? lhooks Gear & Maintenance 8 02-22-2006 09:40 AM
Varnishing Teak Veneer Stormer Gear & Maintenance 2 07-12-2003 04:45 AM
Varnishing Teak DICKWATERS Gear & Maintenance 0 06-09-2001 06:43 AM
