Old 03-09-2013
Minnewaska will become famous soon enough
Re: What shim material to use between the transom & motor mount?
Same identification system in the US, on bottles and plastic containers. At least they look the same. I don't think you would find one on a cutting board.
Is there a starboard fabricator in your area? Sounds like you only need a piece of scrap. I would seriously consider using a piece of teak or mahogany, which can also be found in scrap.
Jeanneau 54DS
  #12
Old 03-09-2013
marcberoz is on a distinguished road
FinallySailing - I briefly looked around on-line. Some cutting board labels specify polyethelene but most do not. Any additional detail may say antimicrobial.
Minnewaska - I'll do more looking for a fabricator. Didn't find anyone close by but I'll ask at my marina.
Thanks All. I appreciate the help.
Marc
  #13
Old 03-09-2013
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
For recycling purposes and labelling?
All the polythenes will probably be the same label. Indoor, outdoor, low density, high density, the question is whether it is any-poly-thene or not-poly-thene. Dollar store, finest export grade plastic. At that price, you know?
To be sure of what the plastic is, you'll have to order from a plastics supplier or other industrial source at matching prices. i'd also have a limited amount of faith in any label at the dollar store since one of their sources is after all mislabelled goods being sold on clearance.
  #14
Old 03-09-2013
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by MarkSF View Post
Simple solution - paint it, whatever the grade.
Lotsa luck! That would be like trying to paint Teflon or Nylon.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #15
Old 03-09-2013
SloopJonB's Avatar
You don't really need much other than something solid that is thick enough. Some kind of plastic would probably be best to reduce maintenance - if you have a fiberglass shop in your area you could get a bit of G2 (prefabricated fiberglass sheet) of the proper thickness.
  #16
Old 03-10-2013
Having the stainless bracket modified to stand off further, is probably a pretty good solution to.
Jeanneau 54DS
You may post attachments
You may edit your posts
Outboard Mount and the transom of a Cal 20 lostcoast Cal 9 03-04-2013 12:26 PM
Transom Mount Transducers cb32863 Electronics 8 09-01-2011 02:12 PM
outboard motor on o'day 27' - transom strength? seamoosecap Gear & Maintenance 11 11-18-2010 08:06 AM
Transom Mount QuickMick Gear & Maintenance 10 03-11-2010 08:54 PM
Reinforcing transom for motor mount and ladder. zz4gta Gear & Maintenance 1 06-11-2008 06:24 PM
SEO by vBSEO 3.6.1
