Raritan toilet expertise sought. - SailNet Community
post #1 of 10 Old 03-08-2013 Thread Starter
TQA
Bombay Explorer 44
TQA's Avatar
I have a boat built in 1978 with two Raritan heads. It came to me a few years ago with many spares including rebuild kits which are marked aft head and FWD head. The kits are both marked PHII PHEII but the FWD head ones are marked 1200C which I gather is the pump body.
I only use one head. The other is not connected. [ Don't ask ]
My question is are the complete pump units interchangeable. I would like to have a pump unit that is ready to go in case of a failure. It looks like they should be as the flap valve that fits under the pump unit is the same for both.
However I would not like to find out the hard way that they are not interchangeable.
A second question is that both pump bodies have some external cracking but the cracks do not seem to extend through the housing. Are the bodies known to fail. I am sensitive to the possibility of failure of older plastics as my beloved Salomon SX 91 Equipe Ski boots had to be retired when one broke in half.
TQA is offline
post #2 of 10 Old 03-08-2013
Re: Raritan toilet expertise sought.
Raritan is still in business and I've received prompt responses to such questions directly from them.
http://www.raritaneng.com/
But I don't see why the pumps wouldn't be interchangeable.. the base bolts and hose in/out are the same, yes?? I know that the flush/empty valves differ depending on age, but even then the pumps themselves are swappable. Can't recall the difference the 'E' makes....
Faster is offline
post #3 of 10 Old 03-09-2013
billyruffn's Avatar
I think the only difference between the PH II and PHE II is that the PHE has an electric motor to drive the pump shaft. The internals of the pumps themselves should be the same and therefore the parts completely interchangable. As Faster suggested, call Raritan for the definitive answer. The 1200 C parts kit may include the parts for conversion of the pump from PH to PHE???
With regard to the cracking.... if the heads in question are original equipment (1978) it wouldn't surprise me that they might be cracking here and there. I've had a PH II in service since 2001 and have replaced the base unit once and the pump housing once. I've rebuilt the pump probably 4-5 times over the years. You'd be surprised the difference a new pump housing can make in the power of the pump.
The cracking may be caused by age, or it could be the result of prior owners using strong acids to clean the system. I was once an advocate of using diluted muriatic acid to clean the scale off, but we had a catastropic failure of the base of the head after a few years of using the acid. I've heard that other cruisers have had the same problem, so I have now switched to vinegar and changing out pump parts and the hoses more frequently. Apparently the strong acid has some effect on the plastic that does not lead to pleasant outcomes.
If the hoses on your boat are original, replace them.
billyruffn is offline
post #4 of 10 Old 03-09-2013
We had one of the early versions on our last boat, with a flush/dry valve that had to be turned several turns (rather than the 90 deg turn of the current style).. What failed on ours was the plastic bits in the pump handle linkage. We had that boat 12 years and that was the only issue, aside from periodic servicing. We had a SS replacement fabricated..it's likely still going strong.
We have the same (newer) head on our current boat, and it's been very good too.
I remember inquiring with Raritan about replacing that old-style pump body with the newer flush valve, no problem, but it was $250 (15 years ago) so we kept turning the valve The newer model also has a bleeder fitting on the pump, we've had to replace that since it was inconveniently 'squirting' onto your foot during the pumping action.
Faster is offline
post #5 of 10 Old 03-09-2013
Capnblu's Avatar
Crack in the poo poo pump? Ummm I would replace... can't be good...
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #6 of 10 Old 03-09-2013
Why do one need it in the first place?
Speedycat is offline
post #7 of 10 Old 03-09-2013
Seņor Member
PorFin's Avatar
TQA,
After reviewing the exploded parts diagram (look here ) I think you will be safe.
Before you get it installed, you might want to tear it down to see if you can determine if it is a pre- or post-1992 model -- there's a minor but important difference in the pump seal assembly, and the two are not interchangeable. The repair kits are different, and if you have the wrong one you are gonna be stuck (BTDT ).
________
'85 BYB Vagabond 39
PorFin is offline
post #8 of 10 Old 03-09-2013
aeventyr60's Avatar
I had the Raritan PHII for many years. I rebuilt it several times, joker & flappers usual suspects. Went to buy a new pump and it was more expensive then a new Jabsco, so bought new and canned the Raritan. Funny thing, I had to carry the new toilet across the border from Singapore to Malaysia, boy did the Malaysia customs give give me some grief, they could not possibly understand why anybody would be carrying a toilet across the border.....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #9 of 10 Old 03-10-2013
MARC2012's Avatar
Ck the flapper valves the holes may be different.New holes 1/2 old 3/8?smaller.They will not seal.marc
MARC2012 is offline
post #10 of 10 Old 03-10-2013 Thread Starter
TQA
Bombay Explorer 44
TQA's Avatar
Only seems to be one flapper valve listed now.
I think I will get a new pump body and build my bits into that and keep the other as a spare as it seems that they are interchangeable.
TQA is offline
Looking to buy our first sail boat, your opinions/expertise are wanted marker199 Boat Review and Purchase Forum 6 04-28-2009 01:27 PM
RARITAN PHII Standard Hand Toilet Stillraining Gear & Maintenance 5 10-09-2008 11:59 PM
head...Raritan that is.... NCountry Gear & Maintenance 9 07-22-2008 04:16 PM
Raritan Raw Water Strainer's Stillraining Gear & Maintenance 13 07-07-2008 08:42 PM
Main Bulkhead Expertise jbibb Sailboat Design and Construction 10 04-27-2008 09:40 PM
