Planar Heater Install advice - Page 2 - SailNet Community
 6Likes
post #11 of 28 Old 03-14-2013
Maine Sail's Avatar
Re: Planar Heater Install advice
Originally Posted by mitiempo View Post
A Wallas will reliably start on 12 volts. If the house bank is large as low as 11 volts actually. Once started - 10 amps for about 4 minutes - they will run reliably as low as 10.5 volts.
As far as longevity we regularly service heaters a decade old. And our customers are often heavy heater users. In the interior of B.C. many are out on aluminum sportfishing boats as soon as the ice on the lakes melts. It makes good heat mandatory when the water temp is just above freezing.
The warranty is time - 3 years - or 2000 hours, same as Espar I believe.
I have both installed and sold Wallas products. I am currently employed by Wallas Canada. I am installing a Wallas in my own boat as well.
But my main reason for posting was to warn about the Russian products.
My main reason to post was also to warn about the Russian made products too.
The Wallas actually has 1 year more warranty than the Espar but both limit the warranty period to 2000 hours. Espar does not limit use of live aboard or commercial but does require service to be done by an "Espar Certified" installer.... As I said none of them are perfect and the warranty small print is pretty poor on all of them..
Personally I don't think the ultimate heater for boats has been built yet.
Perhaps you can help me with the issue I had with the Wallas that would not start with low battery power? Feel free to PM me.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 28 Old 10-15-2013
Hi all I am new to the site but have browsed it and others a lot when I was looking for a heater for my tug. I just wanted to chime in here as I went for the Russian made heater and found everything to be just fine. The hardest part for me was cutting the holes in the boat for the ducting. Not the labour of it but the thought of it. I cannot believe the heat it produces,and the amount of air it moves. I have not been in a boat with a diesel heater before, so I can not give you a comparison but this makes more then enough heat for my boat.I have a Ranger Tug R29 and it has started getting cold up in Ontario, and it warms it up very quickly. Being my first install I had a lot of questions, and all my emails were replied to quickly and gave me the answers I was looking for. I have done a lot of research and I found the biggest problem with any of the heaters is running them at a low setting and having them carbon up. There really isn't a lot to these heaters to go wrong and I of course hope nothing does. I just wanted to let everyone know they do work and make lots of heat..and I am a very satisfied customer
Mark
Tuggie is offline
post #13 of 28 Old 10-15-2013
mitiempo's Avatar
Wallas diesel heaters do not carbon up when run on low - their burner design solved this problem. It keeps the burner just about as hot on low as on high.
Brian
mitiempo is online now
post #14 of 28 Old 10-16-2013
Carbon buildup happens in burner when the combustion temperature is not high enough to burn the fuel completely.
Combustion process in air heaters Planar organized such a way that fuel/combustion air RATIO is kept the same at any regime. Thus, the internal combustion temperature is constant (which prevents carbon depositing) but AMOUNT OF THE HEAT is controlled by varying fuel supply and processed air flow.
vladru is offline
post #15 of 28 Old 02-01-2014
Dirt Free
boatpoker's Avatar
What was that movie ? ..... The ------- are coming
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #16 of 28 Old 02-01-2014
Old enough to know better
Well I actually thought about looking into a Planer for next winter, but there spaming appears to be too much.
mitiempo likes this.
miatapaul is offline
post #17 of 28 Old 11-10-2014
There are more Planar heater models available from the Canadian distributor.
2-year warranty on all products and technical support are provided and backed up by local manufacturer's representative. Any of the spare parts always available and been shipped upon request same day.
vladru is offline
post #18 of 28 Old 11-11-2014
islander bahama 24
newhaul's Avatar
I emailed planar several times for info prior to deciding what to install on my Spencer 42 which was built in Canada but the company has yet to answer my emails been trying for a couple weeks so far
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #19 of 28 Old 11-11-2014
Make sure you have right address: planarheaters@gmail.com
Or call: 604 719-4663. All inquires are always answered.
vladru is offline
post #20 of 28 Old 11-11-2014
islander bahama 24
newhaul's Avatar
I used the contact us page on your companies web site I will try one more time
newhaul is offline
Yet another Solar installation thread - comments/advice requested on install specs. wouldrathersail Gear & Maintenance 1 03-23-2012 02:23 PM
Hydronic Heater Install jonfreeman Gear & Maintenance 17 11-13-2011 02:56 PM
Install of Flue Pipe and Cap for Heater ssmith5250 Gear & Maintenance 7 05-26-2011 03:20 AM
AIR-X Wind Generator Install Advice for PCS 37 SVArgo Pacific Seacraft 12 12-20-2008 03:14 PM
C400 Batt install and Inv/CHg install Cruisingdad Catalina 1 08-01-2007 01:02 PM
