Temporary Screw/Bolt Hole Sealant - Page 2 - SailNet Community
 3Likes
post #11 of 12 Old 03-12-2013
Seņor Member
PorFin's Avatar
Re: Temporary Screw/Bolt Hole Sealant
Originally Posted by hellosailor View Post
...And you can't tear aluminum tape with your fingernails, so now you're scissoring.
You must be talking about a really heavy duty aluminum tape, HS -- my experience with standard Al ducting tape is that you can tear it with your fingers just fine.
________
'85 BYB Vagabond 39
PorFin is offline
post #12 of 12 Old 03-12-2013
Say Chris, just a thought:
Ace Hardware still sells black rubber stoppers (corks) in all sizes! Why not just "stick a cork in it" and then you can just pull them out, no cleaning needed.
They're in the little drawers, in the same aisle as the nuts, bolts, other miscellaneous hardware. Probably 1/3 the cost online, even from Ace online, but who else sells black rubber stoppers these days?!
hellosailor is offline
Waterproof Temporary Putty Sealant csommers79 Gear & Maintenance 6 11-10-2010 10:36 AM
Just temporary, but it should hold 71Irwin32 Gear & Maintenance 35 01-13-2010 12:55 AM
Temporary Moorings Dan Dickison Gear and Maintenance Articles 0 07-21-2002 08:00 PM
Stripped screw hole sklamar Gear & Maintenance 3 05-30-2002 06:10 PM
temporary jib set-up sailorman_10 Gear & Maintenance 3 03-29-2002 03:34 AM
