Painting the deck with interlux perfection and intergrip - SailNet Community
post #1 of 4 Old 03-10-2013 Thread Starter
I am redoing the deck paint on my catalina 27. The previous owner painted the deck and used interlux perfection, but first of all he did not take of the deck hardware and he painted over the non skid. So the foredeck is more or less a skating rink. I have been removing the old paint painstakingly from the non skid but i am only half way. So my question is, do I need to remove it all to sand down the non skid underneath and then painting the intergrip on top?
Also I am not sure what type of prime the previous owner used, it is green and I have the feeling the bond between the deck paint and the primer is not that great. But i might be to much of a perfectionist.
Any suggestions and advice would be highly appreciated.
I am also re-coring the deck under the stanchions and under the eyebolts for the lower shrouds. I am hoping to replace the eyebolts with u-bolts.
Thanks everyone for the advice.
MarkusM is offline
post #2 of 4 Old 03-11-2013
Barquito
Barquito's Avatar
Re: Painting the deck with interlux perfection and intergrip
I just sanded all the old paint and non-skid pattern off... took a long time.
Valiant 32
Barquito is online now
post #3 of 4 Old 03-13-2013
Sailing to surf
Beersmith's Avatar
you just need to sand down to the point where nothing is shiny anymore. If you are at all worried about the bond between the old paint and primer, sand it down to the primer and re-coat with Epoxy Primekote.
I re-did my deck last year with perfection and had a lot of success through trial and error. You can read about it all here:
Priming - Part 1
Priming - Part 2
Priming - Part 3
Painting - Part 1
Painting - Part 2
Painting - Part 3
Painting - Part 4
My boat rebuild/sailing blog:
Beersmith is offline
post #4 of 4 Old 03-14-2013
mikehoyt's Avatar
Using the Interlux 2 part primer after sanding as advised above.
Interlux has a wonderful tech support toll free number. Is somewhere on the www.yachtpaint.com site. They will tell you exactly what you need to do. The down side is that it is very difficult to find the number on their web site.
Contact | Interlux
Mike
mikehoyt is offline
Tags
deck paint , intergrip , interlux , non skid , re-core
Prepping topsides for Interlux Perfection harraik Gear & Maintenance 27 05-23-2011 04:46 PM
Interlux Perfection Paint cbarison Gear & Maintenance 6 03-22-2011 04:10 PM
Where to buy Interlux Perfection? superiorvoyager Gear & Maintenance 24 03-01-2010 04:03 PM
My Interlux Perfection Recall FUBAR tommays Gear & Maintenance 2 03-30-2009 07:31 AM
Fixing my defective Interlux perfection tommays Gear & Maintenance 2 03-17-2009 08:48 PM
