stripped thread in lower unit oil fill hole - SailNet Community
 2Likes
post #1 of 11 Old 03-10-2013 Thread Starter
Question stripped thread in lower unit oil fill hole
I'm sure it happened to some of you... I'd over tighten oil fill bolt in lower unit in my Yahaha 9.9. Now bolt is "skipping", that means thread is stripped.
How do you regenerate it with out rethreading it for bigger size ? Problem is that hole is recesed about 3/16 and diameter just big enough to accomodate head of bolt and washer. So I' don't want to use different oil fill bolt.
Any ideas?
suntrek is offline
post #2 of 11 Old 03-10-2013
Junior member, rest old
msmith10's Avatar
Re: stripped thread in lower unit oil fill hole
If there's enough thickness in the threaded female portion of the housing you could try a helicoil. Otherwise you could drill and tap for larger bolt size then either place washers under the bolt head to fill up that 3/16 gap, or alter the head of the new plug so it fits down in the recess (grind down at machine shop or weld smaller head on plug so it matches the original). Given the usual softness of those housing castings, I think I'd take it to a machine shop and get their opinion.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 11 Old 03-11-2013 Thread Starter
Thanks Mark!
I was thinking about the same thing, but I hoped for easy solution. There is nothing easy with this kind of stuf.
suntrek is offline
post #4 of 11 Old 03-11-2013
I've come to like Time-Sert substantially better than heli-coil. Whichever you use, you'll need to be sure you don't leave metal shavings in the gear case from drilling out the current hole. The Time-Sert, will then return the hole to its original size/thread.
http://www.timesert.com/
SimonV and msmith10 like this.
Jeanneau 54DS
Minnewaska is offline
post #5 of 11 Old 03-11-2013
When going to a larger bolt, consider a headless stud for Allen wrench. That would eliminate the head clearance problem in the well. But I don't know if the head is needed to secure a gasket though. On mine - well, the one I have removed and installed on a 9.9 Johnson and now retired, just had a slot in the top of the bolt/stud, there was no head, but maybe there was a seat at the bottom of the hole.
Sterilecuckoo58
Vivacity 24 twin keel
Johnson O/B 9.9
sterilecuckoo58 is offline
post #6 of 11 Old 03-11-2013
msmith10's Avatar
I checked out the link, Minne. That does look like a good system.
Mark Smith
msmith10 is offline
post #7 of 11 Old 03-11-2013
When tapping the new threads use a blob of grease on it to capture the metal shavings.
Sea Dawg is offline
post #8 of 11 Old 03-11-2013
no longer reading SailNet
Alex W's Avatar
You can avoid this problem by sucking the oil out of the dipstick in the future (rather than using the oil drain hole). This is how the oil is changed on most inboards, but it works on outboards too.
Alex W is offline
post #9 of 11 Old 03-11-2013
I think you are thinking of engine oil. 90w lower gear unit oil would be tough to suck out and you can't warm it up.
Jeanneau 54DS
post #10 of 11 Old 03-12-2013 Thread Starter
Smile Re: stripped thread in lower unit oil fill hole
Thank you all for info and tips!
suntrek is offline
block thread for coolant plug stripped... Rockter Diesel 16 12-17-2011 09:26 PM
This is the lower unit oil davidpm Gear & Maintenance 8 11-14-2011 06:03 PM
Outboard Lower Unit Housing millenniumman Gear & Maintenance 0 02-20-2009 02:52 PM
Fill that hole GoodOldBoat Good Old Boat 0 07-23-2007 09:54 AM
Stripped screw hole sklamar Gear & Maintenance 3 05-30-2002 06:10 PM
