Battery Switch Setup - SailNet Community
post #1 of 3 Old 03-13-2013 Thread Starter
HELP not sure if this would work but worth a short. I have two batterys and adding a interveter to my boat but i would like it on a switch and not one that dc panel switch. by my drawing would this work with diodes and two battery switches ?
Thanks
santana30RI is offline
post #2 of 3 Old 03-14-2013
Stu Jackson's Avatar
Re: Battery Switch Setup
No, you should have the inverter fed from the house bank. Diodes cause voltage drop and are way old technology.
For other wiring see these:
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 3 Old 03-14-2013
Learning the HARD way...
eherlihy's Avatar
The diodes, and the second switch, have me scratching my head... What are you trying to do? Why do you have DC running to an AC panel?
Assuming that you have a 1-both-2-off switch, you should only need one switch.
Many marine inverters, are actually Inverter/Chargers, and would come with more complete instructions than you will get here. Here is an example;
However, if you are hard-wiring an inverter, it should normally be connected to a breaker on the DC panel, labeled "inverter." The DC breaker panel would be energized when you select power from the 1-both-2 switch. You must have some form of circuit overload protection for the inverter circuit.
You may want to learn more about them by reading this; http://www.defender.com/html/charger...ters_info.html
or this; http://www.westmarine.com/webapp/wcs...ng-an-Inverter
eherlihy is online now
Tags
battery switch , electrical
Battery Charger and Battery Switch lobosolo98 Electrical Systems 11 10-10-2012 11:34 AM
New Battery Setup arf145 Electrical Systems 27 11-30-2009 02:15 PM
Starting Battery Setup. 1970Columbia34 Gear & Maintenance 19 02-24-2009 09:33 PM
Battery Setup: Blue Sea ACR? SEMIJim Gear & Maintenance 34 09-10-2008 11:49 AM
dual battery setup. dorourke Gear & Maintenance 16 06-07-2007 02:03 AM
