-   -   Better than a PFD. A wearable liferaft!!! (http://www.sailnet.com/forums/gear-maintenance/97560-better-than-pfd-wearable-liferaft.html)
MedSailor 03-14-2013 12:07 AM
I've been designing something just like this in my spare time. Switlik has already done exactly what I had in mind. Check this puppy out. It's a solo liferaft that you can wear in a harness similar to how you wear a pfd. For the cold waters of the NW USA coast a PFD is generally just so that the coast guard can find your body. This puppy might give the MOB quite a bit of time.
Switlik - ISPLR Single Person Life Raft - Tech Specs
http://switlik.com/images2/aviation/...ee-through.jpg
http://switlik.com/images2/aviation/isplr/belt-pack.jpg
MedSailor
PaulinVictoria 03-14-2013 01:50 AM
Re: Better than a PFD. A wearable liferaft!!!
I'm assuming you wiggle out of the harness before inflating, otherwise you'd better hope you deploy only when face up :)
cruisingdream 03-14-2013 07:28 AM
6.2lbs doesn't sound like a lot until you have to wear it for several hours.
Resolute_ZS 03-14-2013 07:48 AM
I was going to post exactly what Paul and cruisingdream said.... but I think I'll stay tethered to the boat and not go overboard. Neat idea, though.
chucklesR 03-14-2013 09:16 AM
For a solo sailor on a budget, maybe.
at 1k each not a good option for a crew of two.
denverd0n 03-14-2013 11:07 AM
Heavy and expensive, but a very interesting idea, nonetheless.
Barquito 03-14-2013 11:14 AM
Interesting idea. I wonder how much heat loss there would still be. Looks like it would deploy with some water inside, and a single layer of plastic between your body and the cold water of the Salish Sea. Survival might be better (but not visibility from the air) in a gumby suit.
Edit: However, upon reading the link, they do provide a bailer.
flyingwelshman 03-14-2013 01:21 PM
RobGallagher 03-14-2013 01:34 PM
From the drawing, it appears to have a beer koozie built in. That alone is a selling point.
pcarlson 03-14-2013 01:55 PM
As mentioned it could get cold. Also what is this;
Features
Streamlined sea anchor deployment allows canopy venting.
If it is sealed, O2 becomes an issue. If air can get it so can water.
Nice place to hide when the wife is looking you though.
