Finish for new mahogany - SailNet Community
 3Likes
post #1 of 19 Old 03-15-2013 Thread Starter
JoeLena's Avatar
Hello all. I've been refitting an older Rhodes 19, and am ready for the finishing touches. The boat has new mahogany throughout and I'd like to ask for recommendations on finishing the new wood. It is my first boat, so not sure on what is best. I'm a woodworker, and like a nice finish, so I don't want to just throw anything on her.
I see that Cetol is popular and looks like it would do well. I would like to have something as clear as practical and not glossy. The boat will be covered most of the time, and garaged a good bit, so it will not be exposed to the elements so much. I'm not adverse to maintaining the finish, but would rather spend time on the water of course.
The varnished look is not that appealing to me, but perhaps I've just seen worse than average work.
Other ideas on what to use?
JoeLena is offline
post #2 of 19 Old 03-15-2013
One of None
deniseO30's Avatar
Re: Finish for new mahogany
In or out? Cetol makes a clear, but varnish does really really well on mahogany. True varnish will go very dark with age, so you may want to go with spar urethane "varnish"
Photos please!
My last project!
deniseO30 is offline
post #3 of 19 Old 03-15-2013 Thread Starter
JoeLena's Avatar
Out. Yeah, I really do not like the darker look, so the clear would work better.
JoeLena is offline
post #4 of 19 Old 03-15-2013
bljones's Avatar
If you would rather spend time on the water than refinishing, forget Cetol and simply varnish it RIGHT the first time.
Or paint it.
I have a buttload of wood on my boat, all of it finished bright, none of it finished with Cetol.
(Can you tell I am not a fan of Cetol, the naugahyde of brightwork finishes?)
if you do a full varnish schedule the first time, you don't have to revarnish every season, or even every two seasons.
or even every 3 seasons.
I am the laziest slackest SOB you ever met, so anything that cuts down on my maintenance workload makes me happy- investing the effort into doing the brightwork right once beats having to do it again annually or semi-annually.
First off, pick up "The brightwork companion" by rebecca wittman. It's a great guide to doing brightwork, and the photography will make a varnish convert out of anybody.
wipe down bare wood with thinner. Lay on 2 coats of varnish thinned 50%. sand the surface to get rid of imperfections and cut the gloss. lay on two more coats thinned 25%. sand. lay on two coats thinned 10%. Sand. lay on a coat thinned 5%. sand. lay on a thin full strength coat.
Nod and accept the compliments which will come your way.
You can usually "hot coat" the thinned coats if you use a quality varnish.
My favourite varnish isn't available in the US, a lot of wooden boat guys swear by, of all things, Behr Spar Varnish from home depot, but i have't tried it so i can't recommend it or swear you off of it. Epifanes is always a good choice. Find one you like and have fun!
It's 5 o'clock somewhere:
bljones is offline
post #5 of 19 Old 03-15-2013
Tartan 27' owner
CalebD's Avatar
Many of the Wooden Boat forumites swear by le tonkinois varnish. I haven't used it but apparently it is an "old school" varnish with not so many high tech additives.
Harder to find than the mass market brand stuff.
Use an additive for matte or satin finish.
Le Tonkinois Classic varnish and Vernis No1
Everybody has one:
CalebD is offline
post #6 of 19 Old 03-15-2013
rbrasi's Avatar
I have replaced and finished all the mohogany (honduran) on my boat with cetol. I did so because I was advised to by a guy with the same boat and it looked good to me.
While most of it is covered by canvas, I can see how the parts that are exposed have lost luster and thickness in the year since. The covered parts are holding up nicely, but to me that defeats the purpose. If I had it to do over , I would varnish the way described above. I was planning on selling the boat before the cetol would fade, but plans change....
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #7 of 19 Old 03-16-2013
I've used just about everything there is. Ironically, after two winter brightwork failures on my cockpit table, I've gone back to the original. Epifanes clear spar varnish. Its been around for 100 years, despite all the new fangled coatings, for a reason.
I'd forgotten how much nicer it is to work with real varnish. Its a bit time consuming, as you must wait at least 24 hrs between coats and 6 to 10 are necessary, depending on exposure. You must also sand between coats, but that also allows for a smoother finish and its easier to thoroughly recoat, when not applying over another shiny surface.
They make a variety of matte, satin, gloss etc.
I know you aren't a fan of gloss, but here is my work in progress. 6 coats, I may get 10 on before I'm done. Its a leaf from our cockpit table. The reflection is the pic hanging on the wall behind it.
bljones and MooGroc like this.
Jeanneau 54DS
Minnewaska is offline
post #8 of 19 Old 03-16-2013 Thread Starter
JoeLena's Avatar
So you all have just about convinced me. Varnish is the way to go.
That is beautiful Minnewaska, might make me rethink the gloss finish!
The time is not really an issue, and the sanding I can tolerate, so I think I'll give the varnish a chance.
I appreciate all of the input, I should have some finished photos in a couple of weeks I'll post. So far I'm pretty pleased about the results, even if there has been a lot of trial and error involved to get there.
JoeLena is offline
post #9 of 19 Old 03-16-2013
snake charmer, cat herder
zeehag's Avatar
hand rubbed oil, no stain. mahogany is a pretty wood. doesnt need stains or colorings, which are found inmost finishes on the market.
btw--cetol looks crappy on mahogany. just saying from experience with many woods.
good luck and enjoy whatever you choose.
formosa 41, cruising tropics
zeehag is offline
post #10 of 19 Old 03-16-2013
bljones's Avatar
Attachment 13641
Foam brush?
bljones is offline
teak or mahogany flyboy11 Gear & Maintenance 2 05-01-2012 09:23 AM
30 foot Mahogany Yawl Jarerex Boat Review and Purchase Forum 5 12-26-2008 03:20 PM
Epoxy mahogany core bg9208 Sailboat Design and Construction 6 11-04-2008 12:21 PM
Choosing finish for mahogany project superdave Gear & Maintenance 9 03-05-2007 11:20 AM
