Roller Furling Halyard Wrap - Page 2 - SailNet Community
post #11 of 11 Old 03-18-2013
HANUMAN
RobGallagher's Avatar
Re: Roller Furling Halyard Wrap
Another thing I meant to add, then forgot until I read some of these other posts;
If the halyard is very tight and the upper unit/bearings are worn it might bind, causing the halyard to try and wrap. Try playing with the tension.
Too loose will cause wrap.
Too tight can cause wrap or make it very hard to furl.
Of course changing the angle will probably cure both ills. But, until you can get the mast down or get up the mast, try experimenting with the tension.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
Halyard wrap chef2sail General Discussion (sailing related) 11 07-08-2011 01:17 PM
Halyard Tension on Roller Furling System countdemonet General Discussion (sailing related) 6 06-01-2010 05:02 PM
Problem with Halyard Wrap welshwind Gear & Maintenance 4 06-24-2009 04:00 PM
Headstay/halyard tension to improve roller furling performance teshannon Gear & Maintenance 15 07-06-2007 09:59 AM
