how to remove furling head/genoa sail - SailNet Community
 2Likes
  • 1 Post By Minnewaska
  • 1 Post By svHyLyte
post #1 of 10 Old 03-18-2013 Thread Starter
I have a head sail/ genoa that I want to bring in for repair but am unsure how to remove from the furlex roller furling. does anyone know how to remove the sail?
mbaillie is offline
post #2 of 10 Old 03-18-2013
Re: how to remove furling head/genoa sail
Just unclip it from the furler drum, let the halyard go and pull it down by hand.
chris_gee is offline
post #3 of 10 Old 03-18-2013
This should go without saying, but just in case. You have to unfurl the sail first, then as chris g says. Best to do so in very light wind, so the boat doesnt' try to sail off the dock/mooring, while you're doing it. I also prefer to leave the sheets attached until she is fully down on the deck. If you have enough room to pull the sail down, without unclipping it from the bottom first, that also helps keep it on deck.
Faster likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 10 Old 03-18-2013
TQA
Bombay Explorer 44
TQA's Avatar
Always have at least one line which is secured attached to sail until it is fully bagged.
Have a sail tie handy to tie sail to life line while you untie the halyard.
Tie halyard to pulpit BEFORE you attend to sail.
Having a second person around to help you flake the sail is good and almost essential if there is any wind.
TQA is online now
post #5 of 10 Old 03-18-2013
Old as Dirt!
svHyLyte's Avatar
Depending upon the size of the boat, a trick that can make your life a bit easier is to ease the sail out a few feet, remove one of the sheets (not both) and begin rolling the sail into itself toward the foil. a couple of rolls at a time as you ease more of the sail out. Done right, you'll end up with the sail completely rolled into itself with only the tape in the slot on the foil. Then release the tack and have a helper free the halyard. The sail will drop as you drag the bottom of the roll aft between the mast and the shrouds. With that you'll end up with the rolled sail on deck. You can then release the halyard, add a few ties along the length of the sail and accordion fold the sail over on itself starting at the bottom and bag the thing. I used to do this with the sails on our Cal 2-29 when we owned that boat and it seemed to make life easier.
FWIW...
juggleandhope likes this.
svHyLyte is offline
post #6 of 10 Old 06-11-2015
Does --- anyone at all HAVE A LINK TO A VIDEO showing the process from A - Z?? I have a Selden Roller Furler on a 44' boat-- and I'd like to get it correct the 1st TIME without hurting, maaming or damaging a friend or the BOAT!! .
EvelynL is offline
post #7 of 10 Old 06-12-2015
Don't fret so much. As long as the wind is calm, just give it a try. No one will get hurt, it's just awkward until you get the hang of it. The worst outcome is you have a poorly folded sail that is twice as big as it should be. You can always refold a sail on shore. Then you'll have a better idea how to improve your process next time.
Jeanneau 54DS
post #8 of 10 Old 06-12-2015
celenoglu's Avatar
If there is more wind than expected, it is better to moor or anchor and lower the sail. This keeps the sail on the boat.
celenoglu is online now
post #9 of 10 Old 04-15-2017
Have just come back from trying to get foresail of Furlex system on Catalina 27. With halyard fully loose will not pull down, seems to be stuck at the top. There is an elastic string in a groove running from the bottom to the guide point, this broke when we pulled it. Any idea what it does ?
Don Monro is offline
post #10 of 10 Old 04-15-2017
Don, do you mean part of the bolt rope that goes inside the furler came out? Get a pair of binoculars and look at the mast head to see if your halyard is wrapped. If not, you may have cases splitting and need to go aloft to tighten down.
Did it lower at all? If so, try to work back and forth, up and down.
Jeanneau 54DS
Tags
furlex , furling , sail removal
Jib & Genoa Roller Furling patrscoe Gear & Maintenance 9 11-15-2012 10:10 AM
What Head Sail to Buy (Genoa, drifter, or Asym) jetboy General Discussion (sailing related) 17 01-13-2012 03:19 PM
Binding Genoa Furling rk6johnson Gear & Maintenance 11 12-02-2010 09:49 AM
Head sail furling obiec Gear & Maintenance 2 02-18-2003 05:54 AM
