Tires as Fenders - Page 4 - SailNet Community
 15Likes
post #31 of 65 Old 03-19-2013
Re: Tires as Fenders
....I wouldn't want to be seen in a marina so snobby as to ban tyres for fenders. That would be embarrassing.
Which is why they do it. They don't want people with tires for fenders to be seen there, so everyone is apparently happy.
chef2sail and SloopJonB like this.
Jeanneau 54DS
Minnewaska is offline
post #32 of 65 Old 03-19-2013 Thread Starter
casey1999's Avatar
Originally Posted by Minnewaska View Post
If that's not splitting, what is.
The split was in an area where so rub wear occured. I hope WM/Taylor agree with you, but if they deny, not much you can do.
casey1999 is offline
post #33 of 65 Old 03-19-2013 Thread Starter
casey1999's Avatar
Brent is saying he does not want moor his boat in a marina unless tires are allowed. I agree. I do not want marina to tell me how to protect my boat. Anything should go as long as it does not hurt their docks or the environment.
Funny thing, there is a 50 foot fishing boat that uses old boogy boards to fend his boat. He even uses the old leash still attached to the boogy board to tie it off. Well they do not work well, only about two inches of hard foam to protect his boat. I do not really care what he uses, but what bothers me is when the boogy board starts to break up and drop into the water adding foam and plastic to our already polluted ocean. I pick up what I can from the water.
post #34 of 65 Old 03-19-2013
Puget Sound Pounder
kellysails's Avatar
Well, you have to admit it would look a bit Beverly Hillbilly.
Taylor Made fenders have lifetime warranty against bursting or splitting. As you point out, they are expensive, but they are the last you'll ever pay for.
Great info, I didn't know they had a lifetime warranty. I have two flats ones that won't hold air for more than a day. I should have known about the warranty (dumb), thanks for posting.
kellysails is offline
post #35 of 65 Old 03-19-2013
The acrylan slip covers friends made for the tires that they were using as fenders were presentable and seemed to work fine.
Hudsonian is offline
post #36 of 65 Old 03-19-2013
casey, if the boat is small enough, there are things called "dock whips" or something like that. They are fiberglass rods that you bolt vertically onto the dock. Then you bend them down, over the boat, and tie the end to the far side of the boat.
The rod tries to straighten out, which in turn pushes the boat away from the dock.
Not perfect, but they can help if sized properly and at least in moderate conditions.
Tires that are in the water or soaked with tidal changes, will grow barnacles and those of course will chew up the hull. So like any other fender the tires should be kept high enough to be dry.
Of course, you could try something industrial along the lines of shock absorbers, pinned into the dock on one end, pinned into the boat on the other. Or light truck springs from the junkyard, holding off a padded fender board. I have no idea how much "brute force" you'll need to gentle down that dock but sometimes a clever machine shop can suggest something, if you're allowed to install things.
hellosailor is offline
post #37 of 65 Old 03-19-2013
Send a message via Yahoo to dacap06
Hear, hear! I got a free replacement of a Taylormade fender last Autumn when one only a year old developed a leak in the fenderwhip eye, of all places. West Marine traded it for me.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #38 of 65 Old 03-20-2013 Thread Starter
casey1999's Avatar
I looked into the dock whips a couple years ago and could not find one big enough. I will try to find some golf cart tires. Seems those would be flexible enough and small enough diameter to stay dry above water line. They probably do not have steel belts. I will keep with the Taylor fenders (try to get replacement for leaking one) but tires would be a good back up. Thing I like about tires is they cannot fail. Taylor may honor their life warranty, but that does little good if your boat is damaged. At my harbor, I have seen numerous boats damaged after the fender deflated. Problem is the fender is most likely to fail during a big surge event, the time when you need that fender the most.
Curious as to why no maker fills the fender with a light weight foam to make them "run flat" fenders.
post #39 of 65 Old 03-20-2013
I'm going to guess that lightweight foam means open cell, which gets real nasty real fast when warm and damp. And closed cell foam is expensive. And you can't blow mold a vinyl envelope around either one of them, so now you need a whole different manufacutring process. Closed cell will also tend to rupture cells every time it goes squish, although foamed neoprene is strong enough it is damned expensive.
So...it all comes down to money.
Can't you put down some helix anchors outboard of the hull, attach float lines to them, and then pull the boat away from the wall when you secure it?
post #40 of 65 Old 03-20-2013
Yes ,stick a knife in the tire to make sure its not steel belted. Several along your dock not only protect you more if a line breaks, but they also make it much easier for anyone who falls off the dock to get back aboard.
kellysails likes this.
Brent Swain is offline
Fenders? Really? Yep I have a question about Fenders... krozet Gear & Maintenance 32 03-14-2010 10:44 PM
Trailer Tires DBlair8809 Gear & Maintenance 15 06-04-2009 02:33 PM
Puncture Resistant Bike Tires wind_magic Cruising & Liveaboard Forum 18 02-03-2008 07:23 PM
Lets talk about trailer tires! Lancer28 Gear & Maintenance 29 08-16-2007 11:14 AM
