Tires as Fenders - Page 7 - SailNet Community
 15Likes
post #61 of 65 Old 03-21-2013 Thread Starter
casey1999's Avatar
Re: Tires as Fenders
If you do a neat job with pieces of tire and then cover them neatly with indoor/outdoor carpet you could get a pretty cheap and effective solution that could look decent as well.
Taking a bit of care with your workmanship would be the key to making this an acceptable looking solution I think.
Happy to see you are working your way over to my side of the creek...
casey1999 is offline
post #62 of 65 Old 03-21-2013 Thread Starter
casey1999's Avatar
See if you gentlemen can bring this up. Copy righted pic so cannot post:
pics haleiwa marina - Bing Images
Kinda funny. The artist likes tires as fenders. Now imagine the pic with a Taylor Big B. Would not have quite the effect.
Maybe if I use white walls.......
Cawarra Bill likes this.
post #63 of 65 Old 03-22-2013
I often tie to log booms and a couple of tires with drain holes will sink to the correct level and sit well against the low lying log.A piece of carpet lashed to the tire make a great kitty ladder when at anchor and is heavy enough to not bob bob against the hull in a little wave action.
Capt Len is online now
post #64 of 65 Old 03-22-2013
L124C's Avatar
I'm in the same situation with single a single finger berth. I changed slips once, so that the prevailing wind blows my boat off the dock (while blowing my dock mate's boat into his finger). I also fix my fenders to the dock rather than the boat, using fenders I find adrift. I keep my good fenders aboard for when I visit guest docks. I've used the same "borrowed" fenders for years, and they are still very serviceable. If I didn't find fenders I would do the same thing with fenders I purchased, as I agree with others that tires would look "Ghetto" on a pleasure boat. More importantly...."Non-Marking" soles on shoes don't mark because they are carbon free. I could be wrong, however, I assume there is plenty of carbon in tires!
L124C is offline
post #65 of 65 Old 03-23-2013
Closet Powerboater
MedSailor's Avatar
Bare tires are only fit for workboats at a working dock. They are simply not "yacht" (sniff )
20 years ago my wife came home with an armful of 3 1/2" X 5' solid pool noodles (no hole down the center). As soon as I saw them I realized she had bought them to use as dock edging. They are closed cell foam and cost next to nothing - especially at the end of summer at dollar stores.
I lashed them in place using lengths of old sail ties screwed to the float with stainless screws and fender washers. They worked exceptionally well - if a fender flips up you are still completely protected. If you misjudge and rub the dock - nada.
They will deteriorate from UV - lasted three years here before they started shedding. You have two choices about that - spend $20 every couple of years for new ones or spend a bunch more and make up covers like those sold for fenders. If I could use a sewing machine I'd make covers colour coordinated to the boat but as it was I simply used noodles that were colour coordinated to the boat.
After I implemented her idea we started noticing other people using them in the same way - should have patented the idea.
Pool noodles encased in fire hose would probably last forever. Hmmm.....
I like the golf cart tire idea except for it marking up the hull. As much as I would like to say I don't care about that, I do think that my boat is beautiful and if it's white hull were all marked up all the time, it wouldn't be good.
MedSailor
MedSailor is offline
Fenders? Really? Yep I have a question about Fenders... krozet Gear & Maintenance 32 03-14-2010 10:44 PM
Trailer Tires DBlair8809 Gear & Maintenance 15 06-04-2009 02:33 PM
Puncture Resistant Bike Tires wind_magic Cruising & Liveaboard Forum 18 02-03-2008 07:23 PM
Lets talk about trailer tires! Lancer28 Gear & Maintenance 29 08-16-2007 11:14 AM
