Sail slide track won't allow quick reefing - Page 2 - SailNet Community
post #11 of 14 Old 03-19-2013 Thread Starter
Re: Sail slide track won't allow quick reefing
Pretty good description of the issue, and some possible solutions here:
Second reef difficulty on E35/3 [Archive] - EY.o Information Exchange
Rusty123 is offline
post #12 of 14 Old 03-19-2013 Thread Starter
Looks like there are ways to allow the slides to bypass the gate so they can stack at the boom. Here is one example:
US Spars Z190 Mast Gate Plates ~ Beneteau First 235
Rusty123 is offline
post #13 of 14 Old 03-19-2013
Remember you're a womble
PaulinVictoria's Avatar
I have a stopper, take it out, drop a couple of slugs, refit. Not the easiest when things are getting interesting, but it does work and means I can get the reefing cringle directly onto the reefing hook.
I carry a spare stopper in case the other one goes plop.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #14 of 14 Old 03-19-2013
Yorksailor's Avatar
Because I have trouble getting the reef cringle on the hook I run a line from the reef cringle to a cleat low on the mast. While it results in the cringle being a few inches higher it completely takes the slides out of the equation. This becomes even more important if you have second or third reef points.
Phil
Yorksailor is offline
Frozen Sail Slide Outrageous Gear & Maintenance 17 01-15-2013 02:04 PM
Advice wanted: Tides Marine Track and Slide system JackandJude Gear & Maintenance 16 10-19-2012 01:16 PM
Track and slide on bottom of boom hypex General Discussion (sailing related) 3 06-24-2012 10:34 PM
Lubricating sail slide CapnRon47 Gear & Maintenance 14 09-14-2010 08:44 PM
Can anyone identify this track and slide? SteveA Gear & Maintenance 3 05-25-2009 12:23 AM
