New purchase, needs bottom paint, no trailer - Page 3 - SailNet Community
 2Likes
post #21 of 21 Old 03-28-2013
Hi re the sink the ball **** is probably to close when under sail. When the boat is hard over in a fresh wind the water will come up the pipe. Close it off u could also fit a 1 way valve as a precaution for when u forget. Always always double clamp your nylon pipes and check all your ball cocks are in good nick when u slip it if the hull is steel good quality plastic ones are best to eliminate electrolysis for example a nice brass one will soon corrode.be a good chance to check rudder and stuffing box for the prop change anodes if any are left. Good chance the prop will need replacing after 4 years!
JohnnyChristo is offline
Bottom paint for a trailer sailer? minnow1193 Gear & Maintenance 1 03-27-2012 09:42 PM
Where to purchase bottom paint? SteveInMD Gear & Maintenance 1 05-28-2010 10:29 AM
Best Bottom Paint for Trailer Boats NCC320 General Discussion (sailing related) 12 12-14-2009 10:08 PM
Bottom Paint for Trailer Sailor? bulboushead Gear & Maintenance 9 11-13-2009 01:23 PM
Bottom paint for trailer sailor sailgalval Gear & Maintenance 1 01-15-2002 02:35 PM
