Rear Stay adjuster - SailNet Community
 2Likes
post #1 of 16 Old 03-21-2013 Thread Starter
Superior Sailor
Squidd's Avatar
What is the Purpose of the Rear Stay Adjuster
I mean what is the advantage...? I have seen single line hydraulic pull downs, glorified turnbuckles with big wheels, and all sorts of contraptions to "squeeze" a split rear stay...
What for and when do you yank it...??
I should mention I have a masthead rig and split back stay with no known adjuster...
so question is do I "need" one...?
(picture not mine)
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #2 of 16 Old 03-21-2013
Re: Rear Stay adjuster
If you have a split backstay you could easily add the rig shown in your pic, what you'll gain is better forestay tension, less sag and better pointing.
Whether you care or not depends of if you race, or if you have to sail to windward routinely - then the few degrees can translate into big gains, better VMG and that last park buoy....
Faster is online now
post #3 of 16 Old 03-21-2013
BarryL's Avatar
Hey,
The backstay adjuster is used to control forestay tension and main draft position.
When sailing down wind you want to ease the backstay to allow the mast to move forward. This allows a spinnaker to project more sail area.
When headed upwind you don't want the headstay to sag. By tightening the backstay the headstay will get tighter and you will point better. As the wind starts to increase, tensioning the backstay more will move the draft of the mainsail forward so you get less heel and more forward drive.
The boat I race on has an adjustable backstay. The first unit was a threaded rod and a ratchet handle. That unit worked, but was slow and cumbersome to use. The owner upgraded to a hydraulic unit that it much easier to use. Note that the total adjustment is just a few inches from full slack (doing downwind in light air) to full on (going upwind in 20+ kts of wind).
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #4 of 16 Old 03-21-2013 Thread Starter
Superior Sailor
Squidd's Avatar
Is it a constant tension (I could set in the rigging) or just when you need it (add a little trim wise?)
(Barry answered part of that while I was typeing)
"Captin Ron"
Squidd is offline
post #5 of 16 Old 03-21-2013
outbound's Avatar
this will bend the mast and move the top of it aft. That causing the forestay to be tighter and move the center of effort of both the main and jib forward while taking out draft. Want it loose in light air and tight in a breeze in general. Great piece of kit to have. easiest to use with fractional rigs, good with masthead, harder with old style cutters.
s/v Hippocampus
Outbound 46
outbound is online now
post #6 of 16 Old 03-21-2013
Tundra Down
downeast450's Avatar
Faster,
Can you differentiate between its use on masthead and fractional rigs? We use one and the added tension adjustment to the head stay makes a difference on our masthead rig. We know it is too tight when the person in the head can't open the door and get out!
Down
downeast450 is offline
post #7 of 16 Old 03-21-2013
Backstay on a frac is more about mast bend/flattening main.. in fact without jumpers there's not a lot of change to forestay tension.. that's the job of 'runners' and checkstays (which also control overall mast bend, esp on masthead rigs)
downeast450 likes this.
post #8 of 16 Old 03-21-2013
4KSB driver.
SHNOOL's Avatar
Dock
Faster.... I always thought on us Mastheads it was also about headstay sag. You sag it out for more power just off wind, bring it up with more wind and when you are beating to windward. It also helps with rake, and also bend to an extent (not much).
I know with my lowers properly set, I can sag out the headstay with little backstay on, and my aft lowers are tight... but as I bring in the backstay, the forward lowers tighten, aft ease off some, and the forestay really starts to twang. halyard that reaches 8-10 inches aft while hanging a bob at start, to 12-14 inches after full on.
As the wind picks up you can really feel a difference in point as you tension up on the backstay... also in light air, or downwind you can feel the power come back as you back off the backstay... its small and you have to look for it, but it does show itself.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
post #9 of 16 Old 03-21-2013
Post #2 above...
If you have a split backstay you could easily add the rig shown in your pic, what you'll gain is better forestay tension, less sag and better pointing...
Don't think we're disagreeing here...
post #10 of 16 Old 03-21-2013
SchockT's Avatar
On mashead boats the type of mast section you have will determine what effects backstay tension has. If you have a cruising boat with a big stiff "tree trunk" mast section, the main benefit will be forestay tension, which is a good adjustment to have. If your mast is more performance oriented like the tapered Sparcraft mast on my boat, you get the added bonus of being able to bend the mast, which will flatten your mainsail. It should be noted that mast bend does NOT change your draft position (much). Draft position is controlled by halyard/cunningham tension. Mast bend changes the depth of the draft.
SVAuspicious likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Westerbeke W30 (4-91) rear oil leak sanibel sailor Diesel 10 11-05-2011 05:58 PM
What's that "rear stay" on a gaff rig? GregX999 Learning to Sail 9 08-05-2009 10:40 AM
Less 30' with a head in the rear quarter? scottchop Boat Review and Purchase Forum 29 12-01-2008 10:23 PM
Yanmar smoking out rear marinesniper Gear & Maintenance 5 07-26-2008 07:05 AM
Rear Seal Replacement tm3 Gear & Maintenance 2 01-07-2004 03:30 PM
