Send packing the stuffing gland.. - SailNet Community
 2Likes
post #1 of 50 Old 03-21-2013 Thread Starter
Have a go and DIY .....
I am thinking about fitting a pss Shaft seal fitting to the propshaft stern tube instead of using a traditional Stuffing box .
Vetus-Shop.Com : Vetus Shaft Seal with Dual Lip 30mm (Vetus ZWB30A)
With a dedicated water scoop just for the seal that way under travel without the engine running water should still pass through the sterntube.
Anybody else fitted one of these ?????
Robert
macwester26 is offline
post #2 of 50 Old 03-21-2013
ancient mariner
captbillc's Avatar
Re: Send packing the stuffing gland..
i think a stuffing box with new goretex packing is the way to go. it will run cool with just a drip or two now and then. does not wear the shaft either. since i installed it i have not had to tighten the packing. no drips when the shaft is not turning.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
captbillc is offline
post #3 of 50 Old 03-21-2013
Old enough to know better
The issue with the drip-less seals is that when they fail it is generally do so in a catastrophic manor. With a standard stuffing box you will get warnings that is going bad, in the form of drips and leaks. As I understand it they have some maintenance issues as well that if not done correctly it will tend to have a very short life. Cant think at the moment what the issue is but I am sure someone will chime in.
miatapaul is offline
post #4 of 50 Old 03-22-2013 Thread Starter
I have today been again looking around the internet for other options and again changed my mind.
Now looking at a deep water seal.
Large cruisers and the like seem to have no trouble with them.
Just another option Any others suggestions from the members..?
Robert
post #5 of 50 Old 03-22-2013
This is how mine is. It looks factory (20 yrs old?). Works great. No issues. I do check it regularly as part of my system checks before and during use. Don't notice any heat issues. I have a very dry boat; i'd like to keep it that way.
benesailor is offline
post #6 of 50 Old 03-22-2013 Thread Starter
Hi could you tell me please what type or name of the seal you have fitted.
Many thanks
Robert
post #7 of 50 Old 03-22-2013
One of None
deniseO30's Avatar
I've a pss on my boat. nearly 5 yrs. no problems. no drip ever.
My last project!
deniseO30 is offline
post #8 of 50 Old 03-22-2013 Thread Starter
Hi DeniseO30.
Thats great news Just what I was hoping to here.
Many many thanks
Robert
post #9 of 50 Old 03-22-2013
no longer reading SailNet
Alex W's Avatar
How long are people getting between replacing the O-rings on the PSS?
That's my concern with the PSS and what kept me with a traditional stuffing box. Replacing the O-rings on the PSS requires a haul out and pulling the prop shaft. It's also doesn't seem easy to inspect or lubricate the O-rings while the boat is in the water.
Replacing the packing on a stuffing box can be done while the boat is in the water without making a big mess.
Alex W is offline
post #10 of 50 Old 03-22-2013 Thread Starter
Hi Alex W.
I have the same thoughts.
But a post above # 7 has had no problems in a few years.
Robert
packing gland mrkeith Gear & Maintenance 37 02-14-2015 10:15 AM
Help! Leaky packing gland garymcg Gear & Maintenance 3 06-23-2008 09:27 AM
Packing gland bestfriend Gear & Maintenance 3 05-08-2007 12:27 AM
Packing Gland 1970Columbia34 Gear & Maintenance 2 04-10-2007 11:40 AM
Packing gland??????? wildcard Gear & Maintenance 45 01-30-2007 02:39 PM
