SSB Antenna - SailNet Community
post #1 of 9 Old 03-21-2013 Thread Starter
casey1999's Avatar
SSB Antenna
I have Icom 700 Pro with AT tuner on insulated back stay. All works well. Will be replacing the back stay soon and to save $600 in insulators, was thinking of using this 9 foot whip with the tuner.
RadioShack 102 Stainless Steel Whip Element for CB Antenna : CB Radio Antennas | RadioShack.com
I might not be able to tune lower than say 20 meter band, but that would be ok for me. 14,300 seems to be the best freq in any case.
Comments please
casey1999 is offline
post #2 of 9 Old 03-21-2013
Zanshin's Avatar
Re: SSB Antenna
I have a long wire antenna that I raise using my spi-lift from the stern section to the top of the mast as my SSB antenna. It is away from both backstays, is insulated and easy to hoist/remove. Saves using expensive insulator(s) for my backstay and beats a whip antenna.
Zanshin is offline
post #3 of 9 Old 03-21-2013 Thread Starter
casey1999's Avatar
Re: SSB Antenna
I would like to do somthing like that. I could get it to work at anchor, but while sailing, It would get caught up in my standing rigging.
post #4 of 9 Old 03-21-2013
Re: SSB Antenna
Not necessarily. You didn't mention what kind of boat you have.
On many boats, it's possible to rig a semi-permanent "alternate backstay" antenna, such as Zanshin described. I have one on my own boat, and have rigged lots of them on client's boats.
I favor insulated 3/16" s/s lifeline, because it is rugged and can be pulled up tight so it doesn't flop around in a seaway. It works every bit as well as a traditional insulated backstay antenna.
Here's the one on my boat. Been there for some 20 years, and has been thru 5 major hurricanes in the Caribbean.
DSC_0028
If your principal interest is the 20-meter band, may I suggest the best DX antenna of all? A vertical dipole, made of the same insulated lifeline. Construction details are here.
http://wdsg.com/gallery/main.php?g2_itemId=125
Bill
btrayfors is offline
post #5 of 9 Old 03-21-2013 Thread Starter
casey1999's Avatar
Re: SSB Antenna
DSC_0028
Marine Antennas
Bill
Nice pics and installation. I might be able to work somthing like that. Boat is S&S 34 mast head sloop. I do have solar panels mounte at stern that I need to work around.
post #6 of 9 Old 03-21-2013
Cruiser2B's Avatar
Re: SSB Antenna
what about a 20m dipole from mast to stern rail?
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #7 of 9 Old 03-22-2013
Zanshin's Avatar
Re: SSB Antenna
I should have mentioned that my installation and the antenna recommendation came from btrayfors ; for some reason I thought that he wasn't on this forum but on another one.
Bill - the installation is still fine, I take the SSB down only rarely and the ground plane you installed does the job perfectly.
Zanshin is offline
post #8 of 9 Old 03-22-2013
Re: SSB Antenna
So glad to hear it. Hope you're still loving the new boat. I follow your posts and see you're still livin' the good life!
Second day of spring up here and it's COLD....29 degrees this morning and windy.
Take care,
Bill
post #9 of 9 Old 03-22-2013
Re: SSB Antenna
That'll work OK. Main problem, though, is that you can't use it underway.
If you rig your dipole forward, between the forestay and the mast, it's easier sometimes. Leave it that way when at anchor or in a marina, and move the lower end back into the shrouds when underway. Takes only a minute or so. It will work OK that way, but with some detuning.
Then, if you build yourself a little black box such as the one shown on my website, and put it under the gooseneck, you can use a short coax feedline to the dipole, and it won't get in the way when sailing.
Bill
SSB wire antenna to antenna feed-line connector scud Electronics 0 09-24-2012 08:50 AM
vhf antenna for tv scosch Gear & Maintenance 3 03-16-2009 06:24 PM
GPS antenna HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Giulietta General Discussion (sailing related) 34 01-29-2009 12:57 PM
tv antenna dm567 Gear & Maintenance 44 04-15-2007 08:50 PM
VHF antenna demetrik2 Gear & Maintenance 2 01-14-2004 05:18 PM
