Winter Storage Covers - Page 2 - SailNet Community
 8Likes
post #11 of 33 Old 03-22-2013
Learning a bit every day
FinallySailing's Avatar
Re: Winter Storage Covers
Paul, great idea with the ratchet straps ! I might just dare to cover my boat up once again .
FinallySailing is offline
post #12 of 33 Old 03-22-2013
How about making your own? $30 video from sailrite.
Rhapsody-NS27 likes this.
straupe is offline
post #13 of 33 Old 03-22-2013
Silver tarp with a frame made of electrical conduit
https://picasaweb.google.com/1131524...22424488213522
https://picasaweb.google.com/1131524...22405002523858
RonRelyea is offline
post #14 of 33 Old 03-22-2013
Tundra Down
downeast450's Avatar
I can get my winter cover and all its supports into the trunk of my old Saab. That wasn't always the case. I use a 30X20 white poly tarp. The white tarp lets a lot of light in. I shock cord all grommets. I use pipe insulation on hard spots. The ridge is a piece of 1/4" Amsteel that runs from the bow chain plate, over the end of one of my spreaders that sits just aft of the anchor locker hatch (both spreaders are off the mast and the mast is on a rack off the boat). The spreaders are "mounted to 6x6 with a 2x8 base using pipe clamps. The other spreader is centered at the stern rail. I have a strong,4 bolt,well backed, pad eye on the cockpit coaming, centered. It provides the purchase for the back stay adjuster. A third support is a piece of 1" sch. 40 aluminum pipe with a pvc T sitting on it that is aft of the mast step. It is also supported by a 6x6. The Amsteel runs through the T, back over the end of the other spreader, through the pad eye and to a sheet winch. When I tighten the Amsteel using the winch it gets quite taught. I played with the height of the middle pipe to give me enough space in the cockpit under the tarp. This winter has been a good test and it has served just the way I had hoped. No frames, no shrink wrap. I have other boats I cover and buy shock cord by the spool. 3 pieces of 6x6, a tarp, a 40' piece of 1/4" Amsteel and a 5' section of aluminum pipe. A small bag of foam and it all goes into the trunk.
Down
downeast450 is offline
post #15 of 33 Old 03-22-2013
chucklesR's Avatar
Full cover.
Custom made, about 3k
chucklesR is offline
post #16 of 33 Old 03-22-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I'm looking at making my own. Not looking at getting Sailrite's video but I did get one of their machines.
Originally Posted by chucklesR View Post
Full cover.
That looks about the color I'm looking at making my hatch/mailsail covers. Looks a lot like what I was planning for my own cover. Looks good. I need something to protect the wood on my boat.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #17 of 33 Old 03-22-2013 Thread Starter
Have a go and DIY .....
Full cover.
I like the look of this as water is diverted around the fittings and off the boat.
I was thinking along the same lines. Even before i saw this fantastic image..
macwester26 is offline
post #18 of 33 Old 03-22-2013
caberg's Avatar
I used two tarps. Little hard to see the whole setup in the picture below, but that's all I got. I put these on last fall and through 80+ inches of snow this season, a few large wind events, it looks the same as it did when I first them them on. Plus, plenty of airflow going through.
caberg is offline
post #19 of 33 Old 03-22-2013
Full cover.
May I ask who made this cover?
zeilfanaat is offline
post #20 of 33 Old 03-22-2013
Maine Member
BELLATRIX1965's Avatar
I don't know if this will help you in the UK, but I made a frame using metal electrical conduit. You can find the ridge pole fittings on the web to provide for the athwartship braces. I went with white "Ultra Kover" material which was fabricated to exactly my size specifications. This cover has survived 4 winters in Maine, and the cost was very reasonable (here again - cost in US). To secure the cover, I used the "Kover Klips" from the same source. These clips function on a dovetail principle, and they are fabulous!
Here is the link: Kover Klamps - Kover Klip Video
No connection to this company - just a satisfied customer. Oh - and I can't stand shrink wrap - it is an ecological disaster, and it only gets used once!
BELLATRIX1965 is offline
Check Your Winter Covers ! Maine Sail Gear & Maintenance 7 02-24-2009 03:52 PM
Winter Covers? danielgoldberg Gear & Maintenance 89 12-06-2008 03:03 PM
water storage vs. land storage during winter apkaplan General Discussion (sailing related) 1 10-24-2007 05:50 PM
Winter Covers bjoc2314 Gear & Maintenance 2 10-16-2002 04:51 PM
Winter Storage RPerreca General Discussion (sailing related) 7 06-15-2001 06:34 AM
