Replacement Hardware - SailNet Community
post #1 of 5 Old 03-22-2013 Thread Starter
I am trying to replace two cleats that are connected to the mast and that I am currently using to tie off the main and jib halyards. My boat is a 1963 O'Day Rhodes 19 (couldn't be happier with the boat). The cleats are very small (about 2.5"s) and I can't find anything online smaller than 4".
Does anyone have any suggestions? I live in St. Louis and the only chain marine parts store around is West Marine.
Thanks for any help.
tjm240 is offline
post #2 of 5 Old 03-22-2013
overbored's Avatar
Re: Replacement Hardware
try a flag pole shop. not too many of those horn cleats used anymore on small boats
Murrys sport they use some small cleats on the Hobies and Prindles
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 5 Old 03-22-2013
West Marine has 2" and 3" nylon cleats in their own brand as low as $1.99, and Forespar brand Marelon in 3" for $1.49. These are plenty strong, certainly not expensive, and easy to order online. They are not jam cleats like the ones you show, but that shouldn't be a problem.
jgeissinger is offline
post #4 of 5 Old 03-22-2013
Try APS in Annapolis MD. The have many small boat parts.
Sailing Gear: Clothing, Equipment, Hardware, Shoes, Line, Sailboat Parts | Annapolis Performance Sailing
Gary3675 is offline
post #5 of 5 Old 03-22-2013
itsaboat's Avatar
Have you thought of replacing them with cam cleats? If you have halyard winches you could just put an extra wrap and the load would not be that much on the cams.
Pearson 27
itsaboat is offline
Tags
cleats , hardware , midwest , parts
What kind of hardware? mikevehlow Gear & Maintenance 6 10-09-2012 01:30 PM
Hardware Nomenclature sailak Gear & Maintenance 20 05-05-2011 11:19 PM
Running hardware solman55 Gear & Maintenance 4 09-19-2010 06:57 PM
Cabinet Hardware Dmarina Gear & Maintenance 4 06-13-2008 05:23 PM
new blocks and hardware? radly53 Gear & Maintenance 22 03-13-2008 09:21 AM
