Fiberglass buildup around rudder stuffing box - Page 2 - SailNet Community
 2Likes
post #11 of 14 Old 03-23-2013
Tartan 27' owner
CalebD's Avatar
Re: Fiberglass buildup around rudder stuffing box
Here are specs and line diagrams of your Greenwich 24': GREENWICH 24 sailboat specifications and details on sailboatdata.com
Yes, this kind of work can be a real PITA because of the confined working space. I don't envy you that.
There does not appear to be a shaft log hose below your stuffing box. The shaft log hose is a black hose made by the Buck Algonquin company that helps keep the stuffing box located. It also adds some flexibility to the installation. There may be no space in your set up for a hose like this as I can't really see the rudder shaft above the stuffing box. Even a small section of this hose would raise the stuffing box above the floor/hull just enough to make it more accessible.
Allied built sturdy boats, by the way.
Good luck.
Everybody has one:
CalebD is offline
post #12 of 14 Old 03-23-2013 Thread Starter
Hi Denise
Thank you
I thought about that too but then that makes the stuffing box even more encased and tough to access should I need to repack it. I think there's no avoiding grinding away the fiberglass. arghh.
Karen
sailorgirl31 is offline
post #13 of 14 Old 03-23-2013
First you need to determine (if you can) if the leak is coming in around the rudder stock/shaft, or if it's leaking alongside the stuffing box tube past the fiberglass patchwork.
If it's the former I see no need to grind glass except to free up the lock nut. It's certainly not necessary if a simple repack is in order.
If it's leaking past the patchwork glass that's another issue altogether. Are you able to determine what's what on that score?
Your biggest obstacle to a simple repack is the need to remove the Universal joint to get enough clearance to back the nut out and replace the packing.. looking at that arrangement it's easy believe that it's never been properly done. Very tight clearances on all counts, it won't be an easy job, no matter where the problem actually lies...
Pretty boat, btw!, and yes, Welcome to Sailnet.
Faster is offline
post #14 of 14 Old 03-23-2013
Old as Dirt!
svHyLyte's Avatar
Karen,
After looking at the cutaway profile in the Sailboatdata.com screen shot, I suspect that the leakage must be coming from one of two locations: around the shaft through the packing nut, because it can't be locked in place due to the lock nut being embedded in the "gunk"; or, as Faster hypothesizes, possibly up and through that mound of gunk itself, along the outside of the packing gland assembly, which may either be installed in a solid glass rudder-stock carrier tube through the hull lay-up or a conventional packing gland arrangement which relies upon a rubber tube secured to the outside of the rudder-stock carrier tube with double hose clamps and likewise secured to the packing gland assembly itself. In this case, I suspect the arrangement is the former--the packing gland assembly fitted into the end of the rudder-stock carrier tube. If the means of securing the packing gland assembly to the rudder-stock tube fails, it can/will leak and water will well up, along the sides of the packing gland assembly. From the discoloration on the packing gland nut due to corrosion, I am confident there is leakage at that point, although, whether it is the sole leak or just one of two, remains to be discovered. That it has been leaking, and sometimes more rapidly than others is also evidenced by the rust/corrosion in the lower half of the U-joint assembly which could be suspect itself. That assembly is likely held in place on the rudder stock with one or two set screws which, by now, may have given themselves up to rust, but it will definitely need be freed from the rudder-stock to replace the packing flax in the gland.
For what it's worth, I would start by simply freeing the locking nut and tightening and locking the packing gland nut in place. That may solve the problem and you're done. If not, get back to us and we'll give you some more advise regarding a lobotomy for the rudder stock carrier assembly. That may necessitate you cutting an access port in the sole of the cockpit or in the bulkhead on the aft end of the port quarter berth to get access to the hull under the cockpit. In either case, you've got some work cut out for you.
Good luck...
Faster likes this.
svHyLyte is offline
I-28 rudder stuffing box? downeast450 Islander 11 04-06-2011 11:20 PM
Rudder Post Stuffing Box Question Plumbean Gear & Maintenance 4 04-03-2010 07:43 PM
Morgan OI 33 - Rudder shaft stuffing Tgoldsbury Gear & Maintenance 3 03-23-2010 06:39 PM
rudder stuffing box hericsson Gear & Maintenance 1 10-04-2004 04:50 PM
Stuffing Boxes and Rudder Posts Sue & Larry Gear and Maintenance Articles 0 08-21-2002 08:00 PM
