bottom - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 03-26-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: bottom
Owning a 40 year old boat can be a useful exercise in learning to accept imperfection.
Get out there and sail! Enjoy the beauty of sailing, not the drudgery of boat ownership.
jameswilson29 is offline
post #12 of 13 Old 03-26-2013
4KSB driver.
SHNOOL's Avatar
Re: bottom
You have basically the same deal as me... no blisters (well mine have been repaired before, and I have found 1 since)...
But basically if it had anti-fouling on it already at one point, then it likely has has barrier coat as well.
Scrape off all the anti-fouling (only if it's so bad that it's flaking off)... If you do this... do it all. Sand, 60 grit or 80 grit. Once smooth... use a wash to remove any mold release if you accidentally hit fiberglass removing the anti-fouling (trust me you will, lots).
Once that is done, fill the scratches, and gouges (there will be plenty)... fair the keel (make everything smooth-ish)... Then barrier coat. Then bottom paint.
The alternative (that I now STRONGLY recommend)... soda blast the bottom. Its quicker, and less labor for you! Even if you've never done it, the learning curve HAS to be better.
This is what I started with:
and this:
Fairing Compound:
Sanded:
Barrier Coated:
I've since VC17m'd the bottom (I'm freshwater).
But anyway, I have to say the Interlux 2000e Barrier coat is neat stuff. Hard as nails, auto-levels nicely, and is very thick/tough. Also I used interlux water tight for fairing (boy that stuff is a pain to sand).
EVERYTHING is toxic! Copper ablative, epoxy paints, bottom paints, sanding is especially bad. Use a lead paint removal (or better) respirator, and a bunny suit, gloves... the dust gets into everything!
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #13 of 13 Old 03-26-2013
Have a go and DIY .....
Re: bottom
We had 40 plus years of antifouling that we had to remove. ( looked very much like the above images )
This was applied to a 1964 grp 26 foot yacht.We know Both the previous owners they always scrapped off the loose and recoated .....
Click on page 3 for images PAGE 3
I ended up by using an electric hot air paint stripping gun and a FULL faced dust and Fume mask.
It took a long time to get off and then we sanded the whole of the bottom down with a 150 grit sandpaper.
It was one of them nasty jobs that just had to be done.
Robert
macwester26 is offline
A new bottom job DGriffith Pacific Seacraft 19 04-08-2011 10:24 AM
Bottom Job HorizonHunter Gear & Maintenance 6 02-01-2010 08:38 PM
Bottom Job $$$? steveg353 Gear & Maintenance 4 07-22-2008 11:53 AM
Bottom Job Mc51 General Discussion (sailing related) 14 03-10-2007 07:15 PM
Bottom $$$ KPBaker Gear & Maintenance 7 02-25-2002 10:01 AM
