Howto drill center of a rail. - Page 2 - SailNet Community
 1Likes
post #11 of 20 Old 03-26-2013
sailvayu's Avatar
Re: Howto drill center of a rail.
The trick to drilling stainless steel is to use a spray bottle with water to keep a steady stream on the bit. Oil will burn off too fast. Water will boil but still cool. You what to use a slow speed with good stead pressure and keep the bit cool. Do this and you will think you are drilling mild steel. No need for fancy cobalt drill bits but you can use them if you like. Slow and cool that is the trick. If the hole is smaller than 1/4" just use the one bit no need to use a smaller then larger bit. You should go at a speed that will produce long peels of metal from the bit not lots of little flakes. If the bit gets hot it will instantly dull and you will have to resharpen it. I like some of the other suggestions for the home made drill guides, good info there.
Thanks
Capt. Wayne Canning, AMS
Project Boat Zen - Boat and Yacht Repair and Restoration
sailvayu is offline
post #12 of 20 Old 03-26-2013
Maine Sail's Avatar
Originally Posted by BELLATRIX1965 View Post
As Tehas said - the "drill steady" is available at Gemini also:
Drill Steady drill guide - Gemini Products
This drilling rig is made from a water pipe grounding clamp, available at any electrical or home supply retailer - if you are handy, you can make your own and save 50 bucks!
If you are going to buy a Drill Steady buy if from the guy who invented it. John at Gemini!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 20 Old 03-26-2013
tommays's Avatar
Changed things a bit perhaps certainly a common item anyplace that drills holes in tubes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 20 Old 03-26-2013
I love this site! It's a gift that keeps on giving!
tempest is offline
post #15 of 20 Old 03-26-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I used this for drilling on pipes and works great for me.
http://www.amazon.com/gp/product/B0061FY004/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #16 of 20 Old 03-26-2013
Fresh water refugee
katsailor's Avatar
this thread is boring
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #17 of 20 Old 03-26-2013
Dirt Free
boatpoker's Avatar
No jig required. put a cutting disk in your grinder or Dremel tool and cut a tiny grove no wider than your drill bit. the bit will bite easily and stay on center. I've done hundreds of holes in ss tube like this and have never messed one up.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #18 of 20 Old 03-27-2013 Thread Starter
Thanks for the tips guys. There are several Stanchions that are n shaped and welded to the hull I want to add indirect lighting to shine down on the deck, Each stanchion has 2 - 1" horizontal tubes, so I need to drill 3 holes in the bottom bar, upside down grrr.
xymotic is offline
post #19 of 20 Old 03-27-2013 Thread Starter
Originally Posted by rhr1956 View Post
Make one of these out of a good piece of 3/4" hardwood. Place it over the rail and when it shows "level" clamp it and drill.
This seems like the idea I was looking for. If I add a vertical piece on the end, I can square it to the stanchion.
xymotic is offline
post #20 of 20 Old 03-27-2013
Instead of that half-circle groove, make it with two passes on the table saw at 45 degrees. Much faster, easier and will fit the rail better (two lines of contact on the V flanks instead of one line on the curve bottom)
How are you mounting the lights onto the rail now that you have the holes?
rd1900 is offline
Howto: Register your boat in the BVI TradewindSailing Boat Review and Purchase Forum 8 08-28-2013 05:13 PM
The Atlantic - Chicago Howto janmayen General Discussion (sailing related) 17 08-22-2010 06:57 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Our first MOB, well, DOB drill... twisty2 General Discussion (sailing related) 38 03-08-2009 12:28 PM
