-   -   Stanchion eye removal... (http://www.sailnet.com/forums/gear-maintenance/97912-stanchion-eye-removal.html)
SouthBrooklyn 03-26-2013 11:23 PM
1 Attachment(s)
Hello everybody,
I need to take out the brass eye from a bent stanchion, but I can't remove the bolt/rivet/???. Does anyone know how to do it? I tried with a hammer and a pin, but it didn't work.
Thanks,
HP
katsailor 03-26-2013 11:36 PM
Re: Stanchion eye removal...
Remove it using a drill bit
CalebD 03-26-2013 11:55 PM
Horia,
Do you want to save the brass eye, or the bent stanchion, or both?
Have you put a screwdriver through the eye and tried to force it turn?
PB Blaster or similar penetrating oil might help, as might some heat from a torch.
If you don't care about the bent stanchion you could simply cut it away from the brass eye with a tool like a grinder.
Sounds to me as though your boat survived Sandy down in Gravesend Bay. I am glad to think this.
Caleb D.
downeast450 03-28-2013 06:16 AM
Is there a possibility that solder is involved in the bonds holding these parts fast? Can you apply some heat carefully with a propane torch?
Down
mikel1 03-28-2013 07:15 AM
From the picture it looks like that might be just a "dent" or crimp holding that together
SouthBrooklyn 03-28-2013 09:37 AM
Thank you guys, I'll try all of these methods.
Hey Caleb,
The boat was already at the "winter retreat", fortunately. It only got a few boo-boo's, here and there, including two bent stanchions.
Thanks again, everybody!
Hudsonian 03-28-2013 06:26 PM
Around here the boats that were ashore took more of a beating than those on moorings. There are exceptions, however. My boat, which was on a mooring, was totalled when struck by a boat by a boat that had broken away.
katsailor 03-28-2013 06:40 PM
it's all funny until someone loses their eye :laugher
Leocat66 03-29-2013 07:12 PM
We went through the exact issues after "KATRINA". We had the bronze eyes which we removed and used in new stainless tubing, the old having been bent. Our eyes were held in by what is called Roll Pins. They are stainless and a punch was used to remove them. They were very tight and had been there a long time. We ordered new pins on the net and replaced several.
