-   -   Sharing through-hulls and pumps (http://www.sailnet.com/forums/gear-maintenance/97926-sharing-through-hulls-pumps.html)
dtempleton 03-27-2013 02:46 PM
My 50' custom sloop has lots of bells and whistles some of which that I wouldn't have selected in bought new, but do want to maintain. For example, three AC units, water cooled refrigerator, and watermaker. In sum, there are 13 through hulls below the water line, and 11 at the water line.
Partly stemming from a sea strainer that needs repair, I'm wondering if I can merge the function of two or more of them. I searched the archives for through hull sharing, but what I found is related to the engine through hull.
For example, the watermaker and the AC each require a strainer and a pump. I'm thinking of using a single strainer with two pumps, but I'm worried about the watermaker pump pulling air back through the AC unit discharge line, that's above water. I could install a check valve in each, but that adds a level of complexity that could present future problems. Does anyone have experience in this kind of arrangment?
At some level, this is no different in concept from a small sea-chest. Do sea chests have a way of preventing back suction?
outbound 03-27-2013 03:01 PM
re: Sharing through-hulls and pumps
4 Attachment(s)
Have single manifold for all domestic salt water intakes on my new boat. However, AC and refrig units have separate keel coolers/intakes. Could link sinks/heads/washdowns/watermaker to single manifold and decrease through holds but would be nervous about AC/refrig units. Maybe others have more knowledge. Other advantage is it's easy to switch to fresh from salt for those functions when near fresh supply while being able to wash in salt and rinse in fresh anytime. Try to keep fresh to head intakes as should cut down on stink and wear.
