quick bottom job!??!!-- !! - SailNet Community
 2Likes
  • 1 Post By MarkSF
  • 1 Post By FSMike
post #1 of 10 Old 03-28-2013 Thread Starter
Exclamation quick bottom job!??!!-- !!
ELLOOO all !!
I was just wondering how/ whats the quickest way to redo a bottom to relaunch in a month?
i havve already grinded out most big blisters and bveled to a 12-1 slope with 60 grit been drying for a month
i would like to do the following; sand hull and pop the littler ones i didnt get,
clean, fill with west system epoxy and colloidal and make best to fair,,sand, then just prime and paint..
i understand about barrier coatings and such but this is just a temp job u guys see fit?? or let me know how stupid it is just help soon!!!! much love. happy working on your boat-err sailing
jaymckay is offline
post #2 of 10 Old 03-28-2013 Thread Starter
Re: quick bottom job!??!!-- !!
Must be done on apr 25
jaymckay is offline
post #3 of 10 Old 03-28-2013
It's hard to think of anything more likely to result in failure than skipping the epoxy barrier after repairing blisters. Without it, the water can penetrate around the edge of your epoxy/colloidal repairs.
msmith10 likes this.
MarkSF is offline
post #4 of 10 Old 03-28-2013
FSMike's Avatar
Interesting, I've never heard of that. Where does that info come from mark?
wdwright1967 likes this.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #5 of 10 Old 03-29-2013
It's obvious. You've just created multiple penetrations through the gelcoat. Plugging them with epoxy is not enough - you need to seal out the moisture.
MarkSF is offline
post #6 of 10 Old 03-29-2013
Have a go and DIY .....
You should be able to seal the area by sanding around the filled area and then applying a coat of the same resin used for filling.. applied with a rag / sponge / or thinly with a brush. SEALED...
The very same resin you seal holes with after you have drilled holes through either the hull or the deck.
Applies to G.R.P.
Having said that Marine plywood can be sealed using The West epoxy Resin.
macwester26 is offline
post #7 of 10 Old 03-29-2013
I had the shipyard do the same blister removal process for me 3 years ago. They used 2 coats of barrier paint over the reepoxied bottom. Then 2 coats of bottom paint over that. No blisters since then.
It would be foolish to skip the barrier coats after all that hard work. It goes on quick and easy compared to grinding out blisters.
heelangle is offline
post #8 of 10 Old 03-30-2013 Thread Starter
thanks guys.. i do understand the barrier coat is the absolute way to go.. from what i read and understand though epoxy alone is already less permeable than the polyester resin the boat was laminated with.. im not having a boatyard do the work im doing it myself and i need a quick job.. sanding down all 4 coats of paint and then gelcoat is a lot to do in a month not to mention adding the barrier coat layer. when i say in a month i mean the weekends of the month as i work during the week
jaymckay is offline
post #9 of 10 Old 03-30-2013
blutoyz's Avatar
This is why I never ask a question on a forum that I already know the answer for...LOL
If you are tight on time then do what you can, if you are only in for one season next year you may have to strip it again or may not. You will be able to post if it held up either way.
blutoyz is offline
post #10 of 10 Old 03-30-2013
pdqaltair's Avatar
* West system filled with colloidal silica is not the most fun to sand.
* If you've removed glass, aren't you replacing the glass? Depends on how deep and how frequent.
* Barrier coating is just obvious. If the reason for the short cut is a sale, don't shortcut.
* If it is a trip, don't shortcut. Just wait until next season.
I can't IMAGINE stripping the bottom and then doing it over. Make some time, somehow.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
Tags
bottom , epoxy , job , system , west
This is getting really old, really quick bljones Announcements and Suggestions Box 35 04-19-2012 01:01 AM
Quick Hello Richard M Introduce Yourself 3 11-19-2011 09:02 PM
hi every one quick ?? helokittylovr Introduce Yourself 2 04-22-2008 08:26 PM
need help quick KenD Gear & Maintenance 3 06-17-2002 04:12 AM
