Paint to mark anchor chain? - Page 2 - SailNet Community
 9Likes
post #11 of 35 Old 03-29-2013
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Paint to mark anchor chain?
I use green and orange flourescent spray paint made for steel (rustoleum i think). I have many years on it and still going strong. I marked my first at fifty feet (orange about 2 feet long) then every 25 feet thereafter. I dont see the point in marking less than 50 since that is 5:1 at 6 feet of water (remember to add freeboard). The next mark is green-orange which is 75. Next is orange-orange. That is 100. Orange-green-orange is 125, etc.
I like the flourescent because it stands out better, esp at night. It does not glow, but light is easier to read off it. I always leave the colors just above the water so it stands out for others too. You can buy this at home depot or lowes.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #12 of 35 Old 03-29-2013
.....I dont see the point in marking less than 50 since that is 5:1 at 6 feet of water (remember to add freeboard).......
I prefer the first drop to be 2:1 and either drift or back away from it or a few seconds, so the rest of the drop isn't just piling up in a 200lb mushroom or fouling around the anchor itself.
Jeanneau 54DS
Minnewaska is offline
post #13 of 35 Old 03-29-2013
I've found that a segment of white about 6 ft from the anchor gives warning as it clears the bow roller so anchor (on hydraulic) doesn't hook the bobstay. If its home the white is at the wildcat.I've got 25 fathoms of 1/2 inch chain so it's easy to lose count.
Capt Len is offline
post #14 of 35 Old 03-29-2013
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by Minnewaska View Post
Tie wraps seem to last a year or two, but always concern me that they will hang up on the windlass.
I've never had a problem with the tie wraps in my vertical windlass.
I use the USCG and USN practice of marking with red then white then blue. Since I carry less chain than a carrier, I put marks at 10 meter points -- that means when the blue hits the roller I have 100 feet out.
IslanderGuy likes this.
SVAuspicious is offline
post #15 of 35 Old 03-29-2013
Courtney the Dancer
jrd22's Avatar
I've given up on paint, just doesn't seem to last. Different colored small wire ties hold up much better than I expected them to so that's what I use now. I use fathoms on the sounders so I mark every 5 fathoms (30'). I use two ties of one color then a different color, etc until I get to 20 fathoms where I use three white, and white again at 40, etc.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #16 of 35 Old 03-29-2013
Originally Posted by SVAuspicious View Post
.....I use the USCG and USN practice of marking with red then white then blue.......
Also the USGA
mgmhead likes this.
Jeanneau 54DS
post #17 of 35 Old 03-29-2013
formerly posting as eryka
wingNwing's Avatar
We used rustoleum-type spray paint on about 1-2 feet of chain: red at 20 feet (useless on the way down, but on the way up it warns the person at the bow that the anchor is about to come free from the bottom); yellow at 40 feet (nice for a lunch hook); green at 60 feet and blue at 80 feet (where we usually anchor for the night). At 100 feet we switch to rode, marked at intervals with colored zip ties. Put 3 ties at each location, when you see the first one or two break, the third one is still in place showing you where to re-mark the rode.
jerryrlitton likes this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #18 of 35 Old 03-30-2013
Bristol 45.5 - AiniA
I've never seen paint last very long and mud totally obscures it, if you don't clean it well. Tie wraps seem to last a year or two, but always concern me that they will hang up on the windlass.
I bought these a couple of years back and just haven't gotten around to installing them. Believe it or not, our BVI charter had them.
Imtra Chain Markers
We were not pleased with either paint or ties. We use these now and they work well. We have had two or three fall out in four years. No problem with the windlass. Can't imagine why they are so expensive.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #19 of 35 Old 03-30-2013
aeventyr60's Avatar
I go back and forth on paint and cable ties. Paint last about a year on a daily anchoring basis. The cable ties seem harder to see when the chain is whizzing out, especially after sunset. After reglavanizing the chain last year I painted a strip 1 meter long with a base coat of black and on top of that white, every 25 feet. Just need to count the white/black as it goes out....Funny thing a kiwi gal I had on board insisted on using, red and yellow and pink and green..an old school girl ditty..maybe the red, white blue would be easier?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #20 of 35 Old 03-30-2013
billyruffn's Avatar
I use nylon webbing of different colors to mark chain intervals. Take about 5" lengths of 1/2" or 3/4" webbing and sew them around a link so that you have two tabs coming off the chain. Mark the length interval with black magic marker. E.g., use red tabs at 100 ft intervals, yellow in between at 50 ft intervals....so as it runs out it's yellow @50, red@ 100, yellow at 150 etc. Tabs will last for years and if they get muddy so you can't read the numbers, you can always see the color.
PS -- I have never had the tabs catch in the gypsy.
jrd22 likes this.
billyruffn is offline
anchor chain, G70? sapo Gear & Maintenance 0 06-24-2011 12:34 PM
1983 Hood 38 Mark II Anchor Light beckfr Wauquiez 0 05-15-2011 06:42 PM
Anchor Chain dave6330 Learning to Sail 13 10-01-2009 02:42 PM
Anchor Chain TxLnghrn Gear & Maintenance 9 12-24-2008 06:03 PM
Anchor chain geoffr98 Gear & Maintenance 4 07-29-2007 05:09 PM
