Paint to mark anchor chain? - Page 3 - SailNet Community
 9Likes
post #21 of 35 Old 03-31-2013
Wish I never found SN!
SimonV's Avatar
Re: Paint to mark anchor chain?
I had paint, but coral, mud and sand eat it. I now use cable ties and these last for ever, although I do replace the odd one every now and then, come to think of it they used to be black now they are nearly all white with some yellow and I don't know where the red one came from.
jrd22 likes this.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #22 of 35 Old 03-31-2013
using paint...yes as many have said it wears off after a bit and you need to renew it. I might try those specialized markers...
Such a nerd, my marking scheme is red (25'), green (50'), blue (75'), white (100), then double red (125), double green (150), double blue (175), and on a previous bigger boat that had that much chain and could hold it all without sinking double white (200)...etc.
Yea, red, green, blue sequence towards shorter wavelengths (higher frequency) of light....helps me remember, I know, what a nerd , white who knows.
capecodda is offline
post #23 of 35 Old 03-31-2013
Mermaid Hunter
SVAuspicious's Avatar
Not as bad as using the resister color code ...
SVAuspicious is offline
post #24 of 35 Old 04-01-2013
Yea, that's pretty nerdy too!
post #25 of 35 Old 04-01-2013
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by Minnewaska View Post
I prefer the first drop to be 2:1 and either drift or back away from it or a few seconds, so the rest of the drop isn't just piling up in a 200lb mushroom or fouling around the anchor itself.
Hey Minnie, I think you may have missread my post. How I mark my chain has nothing to do with how I play it out. We do not let anything pile at all. Proper anchoring is a skill quickly learned as a cruiser, or your voyage will likely end just as quickly!! We begin dropping the hook after the boat is beginning to slip backwards, or just before. We do not let any of it pool at the bottom. That's a recipe for disaster. We play out the chain until we are at the desired scope and facing with the other boats. At that point I put the engine lightly (if it is not already) in reverse until the slack is taken out of the chain, then give it a good burst to set it into the bottom. If it does not set, I pull it back in and re-do. When my anchor sets, it is SET.
(knock on wood) To date, I have never drug anchor with this anchor. My anchor is over-sized for this boat (x2) and I use all chain. I did drag once on a danforth on one of my first boats, but that is the only time I have ever drug.
I am also a bit miffed at how so many of you have lost the paint on your chain? We anchor out more than most and this paint is still holding strong 5-6 years later! Here, just took this pic:
Now, it has chipped off in many places, but that is why we paint the chain in about two foot segments (which also makes it easier to read). It wouldn't hurt to re-do it, but it is not terribly necessary and I have no shortage of other projects!!
I have used those little marker things. We had them on the 380. My gypsy did eat one of them eventually. But I got tired of them because it is hard to see them clearly at night or when trying to anchor in a hurry. I am a fan of painting. It is cheap, simple, and allows the owner to choose his marking points. Not to mention, the person at the helm can often see the markings as it is played out if the boat is not falling off perfectly straight (which it never does). Plus, if you use the flourescent paint like I suggest, it is easy to see at night both for you and passing boats. By leaving the paint just above the surface, it is easy to spot by both night and day... a real plus for a crowded anchorage or where drunks abound.
My only issue with painting is that initially, some of the paint will chip off and gets down into the locker. It is nothing but a nuisance, but I hate seeing those flakes down in there.
Anyways, my opinions.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #26 of 35 Old 04-02-2013
TQA
Bombay Explorer 44
TQA's Avatar
Cruisingdad
Do you prime the chain, if so with what. or just spray the fluro paint on.
TQA is offline
post #27 of 35 Old 04-04-2013
Originally Posted by TQA View Post
Cruisingdad
Just spray it on. Totally dry though and nothing on the chain which could be a problem for old chain. Porbably wouldnt hurt to prime it first, I was just too lazy. But this paint has held well. I think it was made by rustoleum.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #28 of 35 Old 04-04-2013
TQA
Bombay Explorer 44
TQA's Avatar
Brian
OK that goes on the TODO list for the next haulout. I still think the Caribbean sandy anchorages will rub it off PDQ but it is worth a try. The last time I tried I used brush and oil based enamel over primer. Gone in 2 months.
TQA is offline
post #29 of 35 Old 04-04-2013
I wish I knew the exact paint and I would tell it to you... but I don't. As you can see, mine is chipped off pretty good too, but that took many years of use. However, mine was dry and clean when I put it on. That could be an issue for you.
Let me know how it turns out.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #30 of 35 Old 04-04-2013
CapnChuck's Avatar
We tried paint and as others have said, it doesn't last long. Wire ties constantly break, especially going through the windlass, so they don't work for us. What has worked for years and tens of thousands of miles in countless anchorages is 1 inch nylon webbing sewn through the chain and/or rode. 1 strip at 25 feet, 2 at 50, 3 at 75 and so on. paint can't be seen in the dark but the nylon can be felt and is easier on bare hands than wire ties. It goes through the windlass with no problem, lasts for years and won't wear out on the sea bottom. Chuck
Our Blogs
CapnChuck is offline
anchor chain, G70? sapo Gear & Maintenance 0 06-24-2011 11:34 AM
1983 Hood 38 Mark II Anchor Light beckfr Wauquiez 0 05-15-2011 05:42 PM
Anchor Chain dave6330 Learning to Sail 13 10-01-2009 01:42 PM
Anchor Chain TxLnghrn Gear & Maintenance 9 12-24-2008 05:03 PM
Anchor chain geoffr98 Gear & Maintenance 4 07-29-2007 04:09 PM
